Question about Watches
Second hand bounces - Watches
Second hand not moving
If the Chronograph is running, the second hand may be paused as on of your dials is recording seconds instead of the larger second hand. You shouldn't be running the chronograph timing all the time.
Jan 13, 2016 | Watches
Hi i bought a new ikc1816. The prob that i face is that the "second" hand (longer one) when starts by pressing button "s1" the smaller hand on the above eye (i guess it is called 1/10th second hand) also...
this is a chronograph I think and what you are referring to as the long second hand is actually the chrono hand the seconds hand is at 9 oclock on this model and the smaller hand that is moving simultanusly is actually the chrono revolution counter
May 08, 2014 | Kenneth Cole Watches
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Why isn't the second hand on my Wenger Commando SR not working? The red seconds hand is not moving. The small seconds counter of the chronograph works and the minute and hour hands work.
The large seconds hand will remain at 12 unless you press the upper right button to start it. Pres again to stop it and press the lower button to reset it. The small seconds hand that always runs is the seconds for the time. The large seconds hand is for the stopwatch function. If you like to have it running all the time just start it and leave it running - it won't harm the watch.
Jun 02, 2010 | Swiss Army Wenger Commando 70725 Wrist...
Cant set the second hand to move
The "second" hand on this watch is not actually a 'sweep' second hand, as on other watches.
This is a timer dial. ["Stopwatch 1/5 Second Hand"]
To start/stop this, use the top button (Button "A").
To reset this dial to 12 O'clock, use Button "B", after first stopping it with Button "A".
The "second" hand is the small dial at the 9 O'clock position.
In actuality, you 'could' start this and just not stop it...  Then it would function as a "large second hand". That would be up to the owner. (it might use more battery power though... ?)
Nov 11, 2009 | Pulsar Chronograph Watch
Minute hand and second hand
There is a tool available in the market to remove second hands.
If you have a watch screwdriver you can easily remove both the hands. Just keep the screwdriver in between minute hand and second hand and gently twist the screwdriver. But be careful, it may damage the dial.
Sep 07, 2009 | Casio Watches
The second hand is not moving
make sure your mode is on time and not calender. if on calendar it sticks on the present month and does not move.
May 24, 2008 | Watches
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Watches Logo
22 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
