Question about Building Materials
Why doesn't my Siemens underfloor heating work?
I set the program or put it on continuous and the tiled floor doesn't get any hotter
  • Jonathan Bigler
    Jonathan Bigler Apr 26, 2015
    does the floor get warm at all? ...is the system a floor heater or part of an integrated radiant heating system designed to hear the whole room?
    Problem Solver:
  • 15 Answers
You floor heater is not designed to get hotter or even heat the whole room. It is designed to keep the floor warm And comfortable to the touch. You may set it to continuous but if it's working properly it will only maintain the setting. If it does not get warm at all there is a problem with the system and you should call the help line of the manufacturer and possibly even the installer.
Posted on Apr 26, 2015
    Top Expert:
  • 10,875 Answers
Call for service
3 Suggested Answers
  • 4 Answers
SOURCE: Floor tiles
a friend of mine just asked me the same thing. you could use some adhesive go to home depot and see what there best stuff is !
Posted on Jun 07, 2013
  • 17 Answers
SOURCE: How do I smooth old flooring adhesive enough to put new floor tiles on it
Depending on the size of the room you should use a floor sander or a buffer with a abrasive pad to smooth the serface to your liking
Posted on Mar 12, 2014
Aube th132 problems
The unit is not talking to the sensor. It is most likely the sensor.
Mar 13, 2014 | Hardware & Accessories
Underfloor heating not working
Along with warming up the entire area, people also look to warm up the floor, which can otherwise be harshly cold. Underfloor heating sdystem is the most consistent form as it evenly warms up the complete open space. Infrared Heater Room Heater IR Heater Magneto
Jan 26, 2014 | Heating & Cooling
Siemens underfloor heating keeps flashing 0.5degrees & the floor is HOT! What is wrong?
There is a good possibility that the controller is not set up properly.
The instructions are on the web.
Jun 02, 2012 | Computers & Internet
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
How to heat gun
When you remove old carpet from a room, you will most likely be left with remnants of glued-down backing on the floor. Getting the tile back to it's original smooth appearance can be a tedious task. You will need to make sure that you have a lot of patience and a lot of elbow grease. Start removing the glue by scraping the tile with a heavy-duty wallpaper scraper or a long-handled scraper. Do a quick sweep of the floor. Plug in your heat gun. Once it is heated up, you will want to place it at a forty-five degree angle to the floor and direct the heat on the remaining carpet backing. The carpet backing will loosen considerably as the glue begins to dissolve. The carpet backing will loosen considerably as the glue begins to dissolve. Use the wallpaper scraper to remove the loosened backing. Work in small sections. Once you have removed the carpet backing from the tile, wash the area with warm water and soap to ensure all of the glue and backing are removed. Continue until the entire tile floor is free of carpet backing.
Aug 27, 2008 | B O X Packaging Two Temperature Heat Gun
Siemens underfloor heating sdosent work I set the program or put it on continuous and the tiled floor dosent get any hotter
check your circuit breakers to see if the floor is getting power to it. Consult your operation guide to see if there is an internal fuse.
May 30, 2008 | Heating & Cooling
Building Materials Logo
507 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
