Question about Whirlpool Dryers
I have a whirlpool cabrio electric dryer and when I start it it only runs for few seconds and shuts off and starts back like it's stuck in wrinkle guard mode. What could be the cause of this.
  • 691 Answers
Goto repairclinic.com. Enter your dryer's model number then go to the repair help. It will tell you what is the problem for your particular model or up to the top 9 reasons for your problem. I've fixed major appliances with this site for over 10 years with no prior experience and 100% success.
Posted on Apr 22, 2015
  • 32 Answers
SOURCE: electric dryer shutting off
It sounds like a thermal breaker is engaging and then automatically resetting once it cools off. I'm guessing that if you were to feel the dryer when it was running, it is really hot.
The most likely problem is that the exhaust vent for the dryer is plugged up with lint either within the dryer itself or in the part that is in your wall and exits someplace outside (could be as far as the roof). When the hot air can't escape the dryer overheats and shuts off to prevent a fire.
You might have to take apart the dryer to get at the blockage if it is there but try this first. Unplug the dryer. Make sure that it is cool. Pull it away from the wall. Disconnect the vent hose in the back. Stick your hand in the opening and start pulling out lint. Once you get everything out you can, plug the dryer back in - leaving the hose off - and turn it on. A bunch of lint will blow out. Let the dryer run and see if it shuts off. If not, then you know there is no problem with your dryer.
The next step is to clean out your vent lines. Depending on where they run and how long the run is, this could be a difficult.
When you are all done, connect it all back up.
Posted on Sep 22, 2008
  • 864 Answers
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
Posted on May 29, 2009
  • 125 Answers
SOURCE: my whirlpool dryer keeps shutting off
make sure the vent pipe (and the lint trap) is clear and not plugged with lint
Posted on Aug 24, 2009
protek480
  • 1714 Answers
SOURCE: Whirlpool duet electric dryer doesn't always start and shuts off
Have you cleaned the exit hose thoroughly? Pulled the exhaust line and cleaned?
Thermostat controls heat. There is also a motor centrifugal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement. The element has a contact in the 'timer' circuit too.
It is possible that your element has failed also.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Posted on Sep 01, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
Dryer shuts off within a few seconds and smell burning
That's a sign your motor is bad. Soon it won't start at all.
Mar 13, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
Lights come on, press start and nothing ..
Start Switch is bad, When they go out it leave's a open circuit and all light will come on but no action.
After the circuit is closed then it tells the dryer to start cause the circuit activates both the timer and the motor.
Good Luck
Mike Z
Dec 01, 2013 | Whirlpool Cabrio WED5500X 27" Front-Load...
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
Cabrio dryer end of cycle signal doesn't work
We are sorry to hear of the problem with your Whirlpool Dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your Dryer.
Apr 17, 2017 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Clothes come out super wrinkled?
Just purchased a Cabrio washer/dryer.....biggest mistake I have made in a long time. The clothes come out so wrinkled that you cannot get the wrinkles out wihtout ironing EVERYTHING. These machines are going back ASAP!!!!! I don't care if they are rated #2...they are horrible!
Aug 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
Jun 29, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Hunting boots no no!
If you have one of those fubuloso wrinkle guard whirlpools, they will buzz and start back up on their own in the cool down portion of the cycle the idea being the 2nd timer will keep the clothes from wrinkling by buzzing and then coming to life for a few minutes. Then it waits 10 minutes and if you aint got the clothes out or opened the door then it will repeat.
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
