Question about Garden
I was using my o17 saw today it was runing Just fine I shut it off when I went to start it again it fired on choke seting after that I could not get it to do anything what is wrong with it
  • 691 Answers
All 2-strokes love to run rich when cold thus full choke till it kicks, half choke to start and leave on for 5 seconds high rev's to warm & lubricate, then no choke to run. Restart when hot is 1 pull full choke (you are now flooded) & then no choke til it starts. Try it. Works every time on all of my 2-stroke engines.
Posted on Apr 22, 2015
rwvanlue
  • 486 Answers
SOURCE: Husqvarna chain saw Model 141 running at high rpm's
You may wnat to inspect the intake manifold/boot that mounts inbetween the cylinder and the carb. Also, the impulse tube that comes from the bottom of the cylinder to the carb manifold or carb itself. Sounds like you are running a lean condition. You need to locate the source very quickly, or continued operation will permantly damage the saw. I have listed a few other things to check.
Please let me know what you find. rwvanlue
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 13, 2009
  • 4088 Answers
SOURCE: yesterday i was using the
When it won't run correctly, try removing the fuel tank cap temporarily. If it immediately picks up, suspect tank venting problems. Good luck!
Posted on Nov 12, 2010
eugbug
  • 479 Answers
SOURCE: I have a Poulan 2300
Ensure air filter is clean. Foam elements can be washed with hot water and detergent, squeezed dry in a cloth and re-oiled with a teaspoon of engine oil spread through the foam. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
Check fuel lines aren't kinked or blocked restricting fuel flow.
Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
Check the throttle cable is actuating the throttle plate in the carburettor.
On some machines when the machine is revved, the choke is knocked off automatically, make sure this is happening ok.
Posted on Mar 05, 2011
  • 1015 Answers
SOURCE: I have homelite UT10560 chain
Make sure you have control set on run,not choke or start. Check spark aresstor by removing exhaust cover and cleaning screen of carbon and oil build up with spray carburater cleaner and fine wire brush.Also remove gas cap and make sure that vent hole in cap is open.Otherwise it can draw a vacumn after being ran for awile and be very hard to start.One last thing is make sure that spark plug gap is correct and that there are no hairline cracks in porcelin insulation. Best of luck. Thank you.
Posted on Apr 20, 2011
  • 2239 Answers
SOURCE: saw stops runing when it
Couple of possibilitys here, when it starts to die slacken off the fuel filler cap, if it then picks up again it is a blocked fuel tank breather, the other possibility is the ignition unit breaking down when hot, the only answer here is to replace the unit.
Posted on Sep 09, 2011
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
Have new 450 and is very difficult to start. Lost or didn't get book. How do I start it and re-start it while still warm??
Start procedure is, push the primer as many times as it takes to 3/4 fill the bulb ( you cannot over prime it ) pull the blue choke lever fully out,place the saw on the ground with your right boot through the back handle, crank the engine until it fires once, do not continue to crank the engine with the choke out ( they will not run on choke, only fire ) push the choke fully home, crank the engine until it starts, blip the throttle trigger to bring the saw to idle, warm engine, pull the choke fully out and push in again without cranking engine, this will engage the part throttle, crank the engine until it starts, blip the throttle to bring the engine to idle.
May 18, 2011 | Husqvarna 450 e-series 18" Chain Saw
I have a Husky 435 model that is less than 2 years old and as cut only about a cord and a half of lumber . The saw runs fine when it is running the problem is getting it started in the first place . I...
It should start easily, start with fresh fuel/oil, pump the primer as many times as it takes to 3/4 fill the bulb, pull the choke fully out, crank the engine until it fires once, push the choke fully in and crank again until it fires up, after re fueling a warm engine, pump the primer again until it 3/4 fills the bulb,before cranking the engine pull the choke fully out and in again( this will engage the part throttle ) then crank the engine until it fires up.
May 15, 2011 | Garden
I have homelite UT10560 chain saw. The problem I have is it will start and run when cold. But if the saw shuts off it is very hard to start again. What is the trick to start when saw has been runing...
Apr 20, 2011 | Homelite ZR10926 16" Chain Saw
W-7 Case loader will not start. I ran fine, shut
The fact that it will start on ether suggest it's most likely a choke problem. To see if it's the choke cover most of the air intake, if that makes it start that will confirm it's the choke.
If it starts but then stalls when you back off the throttle suggests a vacuum leak. To find a leak use your ether spray it at the base of the throttle body or carb, where vacuum hose connect or look damaged.
If the engine changes you have a leak there. BE VERY CAREFUL USING ETHER TO FIND A LEAK AND HAVE A FIRE EXTINGUISHER HANDY, FIRE IS A REAL SERIOUS RISK USING THIS METHOD.
May 26, 2010 | Milwaukee Tool Case Heat Gun
How do I start rental model 96.
Place the saw on full choke with the switch on. Pull the rope until it fires. Place the saw on half choke, and pull again, and it will start running. Half choke should release as soon as you hit the trigger.
Mar 23, 2010 | Husqvarna Chain Saw 20" Bar
Chain saw starts runs, bur saw won't start next time it is needed, craftsman chain saw
Steam vacuum? no clue but on your chain saw make sure you check the choke. it would explain why it wouldn't start again.
Sep 27, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
