Question about LG Kompressor Upright Vertical Cyclone Vacuum
Power button doesn't stay on without pressing it all the time
You have to manually push the button to keep the power on
  • John Stangp
    John Stangp Apr 22, 2015
    thank you so much very helpful
  • LG Master
  • 932 Answers
John,
More than likely you will need to replace that switch.
Posted on Apr 22, 2015
My Power head on my Dyson Animal DC39 will not stay spinning. Suction Issue?
There should be a red insert on the right-hand side on the cylindrical bulge behind the brush cylinder. Check that this is moving when you push the button. The red insert should stay pushed in for the brush to rotate. The insert moves in an out as well as rotates in order to lock in the 'in' position. Mine is a little sticky on the rotation and I need to shake the brush head a little in order to get it to rotate and lock.
Jan 05, 2013 | Dyson DC39 Animal Canister Vacuum
Dyson dc25 power switch will not stay on
I called Dyson because I had a similar problem. When I pushed the red button down on my dc25, but it would not stay down. The vacuum would turn on when the button was pushed down, but of course when I let go of it the vacuum would shut off. The helpful telephone tech. Recognized the symptom right away and told me to push down on the button fully and let It flick up like a lighter. I about fell off my chair when that worked right away! Anyways for what it's worth, she said sometimes the mechanism in the buttons gets consnarlitated (my tern, not hers!) and this resets the spring.
Feb 19, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
My on off button won't stay pressed down so the vacuum won't stay running.
Hi Melissa,
I'm sorry to hear you're having difficulties with your DC17. If the on/off switch doesn't seem to be working correctly, it's best if you get in touch with us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 13, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Power button won't stay down.
Sorry to hear you're experiencing a problem with the power button on your DC25.
In case you haven't tried this, give the button a firm push all the way down. If this doesn't resolve the issue, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US) so we can help.
Kind regards,
Jack
Dyson Customer Service
Feb 24, 2011 | Dyson DC25 Animal Bagless Upright Vacuum
Dyson DC07 - I push the power button and it does not stay on, I have to hold it down to keep it running.
Hi, the power button presses onto a small switch underneath the button. Either 1 of 2 things has happened.
1. The Inner swith has dislodged
2. The button you press has became stiff.
Solution
Take the cyclone off
Take the Wand off
This will leave you with the frame.
Switch the power of completely and remove plug from wall socket, just to be safe.
With the dyson facing you near the button at the from you will a small silver srew. You will need to unscrew this using a torx screwdriver. Dyson dont really want you interfering so they use these types of screws.
Once you take that screw out, turn the machine round to face away from you. At the back of where the button is you should see where there is like 2 clips, one on either side.
Put your torx screwdriver into the gap on one side and hit the end of the screw driver with the heal of your hand this will knock the clip out, do the same with the other side and then the facia will come off.
You will then see the wiring. Should see that the switch has maybe came away from the groove its supposed to fit into.
Push it back into place, ensuring that the switch is down, so that you can put the facia back on.
Its a wee bit tricky sometime puting the facia back on if you havent done it beofre, but be patient and you will get it. Out the srew back in and it should snap into place.
Feb 21, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have an older model rca cd clock radio dual alarms. I cannot find my instructions for setting the clocks time. The batteries were dead when the electricity went off. Now the time keeps flashing the time.
For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
There are manuals for several RCA cd clock radios available from their site: http://support.rcaaudiovideo.com/select.aspx?u=manual . Check if your specific model is listed in the menus.
I hope this helps.
Feb 03, 2011 | Vacuums
Power brush keeps going off and on ,when off i keep pressing red button and switches on ...stays on if you keep it up slightly and not fully down
Just had the same problem. Took apart whole power head to look for broken wire and found none. If you see part way up the hose there is a coller with 4 torx screws holding together. This collar is a swivel that allows the hose to spin without twisting or kinking. Take the 4 screws out and open up. You will see 3 contacts that look like fingers that rub on 3 mating steel rings. Wipe the tips of the fingers and wipe clean the rings. Gently bend the fingers out wards so that they apply more pressure to the steel rings. Reassemble and try. Should take no more than 15 mins. Worked for me good luck!
Jan 06, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC 24 pick up head wont spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Jun 20, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson animal, have to hold ON switch for it to work
Pull the wand out of the Vac. Need to use a small Torx bit to take out 2 screws hidden behind the wand storage. Once screws are out, there are 4 push-clips which need to be un-latched. Pry the power panel off and you will expose the two switches (one for power, one for the brushes). Push the power switch down and it should "release" and go back to clicking when pushed. Re-assemble. Took about 5 minutes to fix.
Aug 06, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
LG Kompressor Upright Vertical Cyclone Vacuum Logo
65 people viewed this question
Top LG Vacuums Experts
Think Crucial
Think Crucial
Tim Venetis
Colin Stickland
Colin Stickland
Are you a LG Vacuum Expert? Answer questions, earn points and help others
