Question about Homeright SteamMachine Steamer for Steam Cleaning and Wallpaper
Pressure does not build up and it does not work any more - leaky valve- how do I fix that?
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
Why doesn't carpet cleaner dispense water and soap?
Get a needle and clean all the nozzles, since they work with hot water they tend to get clogged with a white built up.
Aug 27, 2014 | Royal RY7910 Procision Deluxe Upright...
My steamer is no longer producing steam, how do I fix?
To troubleshoot something like this.
1. make sure it's plugged and the outlet is working.
2. Is it getting hot? If not, either the heating element is burned out or not getting power.
3. If it is getting hot check the steam ports for calcium build up (run straight vinegar through it)
Jul 14, 2014 | Garment Steamers & Presses
Elna ironing press manual
I don't have a manual but these are extremely simple to use once and there is a demo on youtube for business shirts How to use Elna Press for Ironing Shirt and other videos from same member show sheets and jeans. Technique is simple, place part of garment onto the board with the rest sitting on your knees (use press sitting down in front of it) to take the weight, lower press closed with your left hand, then bring the spring loaded right handle down to apply the pressure, this has a big spring behind it and applies pressure, wait 2-3 seconds then lift right handle to release the pressure and then using your left hand grip the whole press will want to open up again. That's it! Set the temperature setting on the press and iron from your lowest temperature items first, nylons, up to cottons, linens on the hottest setting last as it will take 5 minutes or so to come up to full temperature. If you have the vapojet spray attachement, then you fill this with tap water and slide it onto the handle, give it a spray with the press open before you close to press and it turns to steam. Cleaning the top hot plate can be done with a special cleaning stick product you can buy (or any similar iron cleaning stick will work too, but you need to apply it to a hot plate so be really careful as you do this, then wipe it off with some waste fabric. Great press to own and perfect for applying interfacing if you are a sewist, (just use a piece of waste fabric so side of the interfacing doesn't attach to the top plate or your bottom cover).
Jul 12, 2014 | Garment Steamers & Presses
Home touch garment steamer model ps-280 wont turn on
If it were left on its possible that the element that heats the water has burned out think blown light bulb have your Mr Test it with a ohm meter to see if the circuit is open
May 02, 2014 | Garment Steamers & Presses
What are the advantages of using a steamer over an iron?
steamers are usually believed to be easier to use and less damaging to the fabric over time
Jan 30, 2013 | Garment Steamers & Presses
Homeright SteamMachine Steamer for Steam Cleaning and Wallpaper Logo
545 people viewed this question
Top Homeright Garment Steamers & Presses Experts
Tom Chichester
ray gallant
Are you a Homeright Garment Steamer and Press Expert? Answer questions, earn points and help others
