Question about La Cornue Kitchen Ranges
One burner on stovetop La Cornue 'AlberTine 36' stove will not ignite, as spark is not arcing as is for other burners... Will light with match and cap is on correctly. Do you have ideas?
SOURCE: stove top burner Spectra XL4
rear left back burner clicks to ignite but doesnt
Posted on Apr 06, 2008
  • 15 Answers
SOURCE: stove top burners not igniting
I would check that the range is plugged in first and that any fuse in the range itself has not blown. Fuse in the stove should be near where the electric line from the wall plug goes into the back of the range. Just follow it down to where it plugs into the range itself.
If all those are fine, check the little wires from the igniters all the way to where they plug into some connector. But unless you had a really busy mouse I dont see that happening to all the wires from each igniter. good luck
Posted on Oct 07, 2008
Jimster
  • 240 Answers
SOURCE: stovetop ignitor
Not that this will fix it for sure, sometimes it does. Remove the top of the burner that is causing the problem, and take some sand paper and clean the top of the ignitor and the bottom of the burner itself. That will sometime cure the problem. If not, you could have a bad spark module, or a wiring issue.
Posted on Nov 15, 2008
  • 530 Answers
SOURCE: Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Posted on Jan 04, 2009
garing
  • 998 Answers
SOURCE: Whirlpool GS465 stove top burners won't ignite
adjust air hoods
thumbs up
Posted on Aug 17, 2009
Where is the pilot light on a GE profile gas stove? The burners suddenly would not light except with igniter.
Please add the make and model number of the stove. Modern gas stoves and ranges do not have a pilot light. They light the gas with an electric spark. On these models, there is a knob setting for "Light" which triggers the spark. If there is no A/C voltage to the stove, you can use a match or butane lighter to light the stove with care.
I've found that the ignition system can fail if the burner caps are not seated properly. Debris in the burner area can also lead to the ignition spark problems. If you take off the burner cap and head (for some models), the electrode will be visible. Clean off any carbon build up on the electrodes for better sparks.
Jan 22, 2017 | GE Kitchen Ranges
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
I have a Magic Chef Stove Model #31003SAW. I
Can you light the burners ok with a match, if so you might need a spark module Whatever you do don't raise the top. Check out this video HERE
Feb 12, 2010 | Kitchen Ranges
On my gas stove, 3 out of 4 burners light correctly. The 4th however will not light- doesn't show a spark. Though you can use a match to light the burner and it works fine. what gives? Can I do the repair?
Feb 10, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Gas burners/electronic ignition
Jan 26, 2009 | Tappan TGF657 Gas Kitchen Range
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
105 people viewed this question
Top La Cornue Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a La Cornue Kitchen Range Expert? Answer questions, earn points and help others
