Question about Cell Phones
After installing SIM recovery pro 2 and inserting my sim sard into the device it says that there is no sim card found. Are there any suggestions as to what is wrong?
shevng
  • 175 Answers
SOURCE: problem no sim card inserted
try to clean the contacts of your sim-card and also on your phone
if not see if your sim-card bends a little try to flatten it. ok...
peace!
Posted on Dec 01, 2007
SOURCE: Inserting SIM card in Motorola V3C
Ahh! but there is a slot. Remove the battery and slide in the skinny sim card where you don't think there is space.....voila!
Posted on Feb 09, 2008
SOURCE: Insert SIM Card
My phones displays the message Insert SIM Card even though it has the SIM Card.
Posted on May 04, 2008
manojro
  • 495 Answers
SOURCE: Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Posted on Nov 26, 2008
  • 567 Answers
SOURCE: Sim card
if this is a new sim never been in the phone before it will require registering if is has been used before in the phone try another sim if that works the sim is faulty
Posted on May 08, 2010
I have lenovo ideapad a10 where do I insert the sim card I see no slot for it
To Install the SIM card:
1)Open the device back cover from the bottom left in direction of the arrow, insert the SIM card to the correct card slot
To remove the SIM card:
1)Open the device back cover from the bottom left in direction of the arrow, press and hold the front of the SIM card, and flip it out slightly.
How to install and remove the SIM card Lenovo A10 70 Tablet Lenovo Support...
Dec 21, 2015 | Lenovo Computers & Internet
How to insert sim card
Probably nowhere. A desktop is not made for that, so I have a Mifi (MobileWifi)
Mine is from Vodafone and is a Huawei enclosure with SIM card slot. this Mifi sends out a Wifi signal I can connect up to 5 computers, tablets or desktops with Wifi-card to.
so for this solution you need:
1. A Wifi-networkcard in your desktop. Laptops do have it standard, because they are meant to be mobile devices.
A Wifi- network card for desktops to be installed inside the desktop.
You will need to install also a driver from a disk or download from support site from the manufacturer.
http://www.tomshardware.co.uk/forum/24164-43-whats-wireless-adapter-desktop
2. A Mifi where the SIM can be inserted.
Do a Google search for mobile hotspot to find a Device for that.
Jul 25, 2014 | Dell Optiplex 755 Desktop Desktop Computer...
CK15I INSERT SIM SOLUTION
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Oct 07, 2012 | Sony Ericsson CK15i X10 txt pro White
My sim is rejected how to activate
1. Power down the Nokia cell phone before inserting the SIM card. If the phone is on when you insert the SIM card, it may not detect the newly placed device.
2. Insert a SIM card from your specific wireless provider. If you are attempting to insert the SIM card of a different company, your Nokia phone may not properly detect or use the equipment.
3. Slide the SIM card completely into the SIM card port on your Nokia cell phone. If the card is not pushed in all the way, your phone will not detect the information.
Aug 19, 2012 | Nokia Unlocked C2-06 Double SIM touch Cell...
Insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Jun 25, 2011 | Nokia Classic 2700 Cell Phone
Nokia c7 sim card removal i don't now how ??
Insert the SIM card and battery
Important: Do not use a micro-SIM or a micro-SIM with an adapter in this device. This device does not support use of micro-SIM cards, and use of incompatible SIM cards may damage the card or the device, and may corrupt data stored on the card.
Follow the instructions carefully, to avoid damaging the back cover.
Safe removal. Always switch the device off and disconnect the charger before removing the battery.
1 Unlock the back cover release latch, and lift the back cover
2 If the battery is inserted, lift the battery out.
3 Insert a SIM card. Use the diagram printed on the device to correctly align the card.
4 Line up the contacts of the battery and the battery compartment, and insert the battery.
5 To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Nokia C7 (8 GB) Smartphone
How to retreave messages from the phone
Instructions
    • Get a SIM card recovery kit. This includes software to read the data on the card, and a device that plugs into the USB port on your computer. Find these kits at your local cell phone or computer store, or online (see Resources for options).
    • 2 Insert the CD-ROM from the kit into the drive on your computer. Windows will ask if you wish to install the application and drivers. Click "Yes" and follow the instructions given to you on the screen.
    • 3 Turn your phone off and remove the battery. Remove the SIM card by lifting the metal gate up and sliding the white rectangular chip out of the slot.
    • 4 Insert the SIM card into the USB device and plug it into your computer's USB port.
    • 5 Go to the Start menu on your computer and open the application that you installed earlier. Go to "File" and "Download Text Messages." This will download any available text messages on the SIM card (both deleted and undeleted) to a window in the software. Note that a text message isn't deleted until the memory slot where it resides has been written over. Once it has been written over, nothing can retrieve it.
    • 6 Go to the window with the text messages and find the one that you wish to undelete. It will be marked in red. To undelete it, right-click on the file and select "Undelete," which will restore the message.
Jan 17, 2011 | Lands Phones
Iphone stuck on restore
this is what i have just found,Hold the home button down (on the front of your iPhone) and connect the device to your laptop/PC while iTunes is open. A message should pop up and say that youriPhone is in recovery mode and needs to be restored. Click on your device (in the iTunes windows) along the main toolbar, then go to the Summary tab.30 Jul 2014
How to Fix an iPhone Stuck In Recovery Mode ' Enigma Recovery
https://www.enigma-recovery.com/fix-iphone-stuck-recovery-mode/ Iphone stuck on restore Google Search
Oct 24, 2017 | Cell Phones
Sidekick 2
Sorry, the sidekick II doesn't have a battery that can be pulled out. You need to pull back the bumper on one side to access the sim card slot.
    1. Follow these instructions to remove your operator-supplied SIM card from your device:
    2. Turn off your device by pressing the power on/off key.
    • Expose the SIM card slot by peeling back the bumper from the top-left edge of the device: t02005-2.jpg
    • Press down on the silver "catch" and the SIM card will spring out of its slot. Remove the SIM card carefully. (Always handle your SIM card carefully since the card and gold contacts can be easily damaged by scratches or bends. Be sure to keep SIM cards out of reach of small children.)
    1. Now insert the SIM card containing the contacts you want to import:
    2. Insert the SIM card into its slot with the gold contacts facing up and the cut corner facing out. t02005-1.jpg
    • When you release the SIM card make sure it is locked into position behind the catch so it doesn't spring out.
    • Replace the bumper and turn on your device.
    GrinningFool
  • www.repairmysidekick.org
  • May 09, 2008 | T-Mobile Sidekick II
    Installing sim card in sidekick II
    hello, hope these instructions help: 1. To expose the SIM card slot, peel back the bumper from the top-left edge of the device. (fig 1) 2. Insert the SIM into the slot with the gold contacts facing forward and the cut corner facing out. (fig 2) 3. When you release the SIM, make sure it is locked into position behind the catch so it will not spring out. 4. Replace the bumper and turn on the device. Any problems, let me know :) Si
    Oct 03, 2007 | T-Mobile Sidekick ID Cellular Phone
    Cell Phones Logo
    Top Cell Phones Experts
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
