Question about Earthway Garden
How to replace impeller on 2030p spreader, unable to remove housing in hopper
4 Suggested Answers
  • 398 Answers
SOURCE: broken hopper
jb weld
Posted on Mar 18, 2009
  • 65 Answers
SOURCE: can I buy a new hopper for my Scotts easygreen
I am sorry you have a broken EasyGreen spreader. Please contact the Scotts help center at 800-543-8873 for a solution.
Posted on May 09, 2011
  • 65 Answers
SOURCE: broadcasting mechanism and fins (in
I am sorry you are experiencing problems with your broadcast spreader. Scotts does have some replacement parts available, but it depends on the spreader you have. Please call Scotts at 800-543-8873 and we can see about a replacement part. Hilary @ Scotts
Posted on Jun 09, 2011
I have a Scotts Accugreen 3000 spreader. The orange plastic teeth on the rotating bar located at the bottom of the hopper are shorter due ot wear. What is the bar name, replacement part number, cost and...
I am sorry to hear about the problem with your spreader. It sounds that you have a broken agitator. We do have replacement parts available. Please call Scotts at 1-800-543-8873 at your earliest convenience. Hilary @ Scotts.
Jun 17, 2011 | Scotts Company Garden
Broadcasting mechanism and fins (in the spreader hopper) broke and came apart, rendering my 2 year old Scotts spreader useless. Where can I obtain the appropriate replacement part
May 18, 2011 | Garden
Can I buy a new hopper for my Scotts easygreen spreader
May 07, 2011 | Scotts Company Garden
How do i calibrate the scotts speedygreen 2000
Your SpeedyGreen 2000 Rotary Spreader spreader was calibrated at the factory. However, a spreader's calibration may change or slip during periods of frequent or heavy use.
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you have any additional questions feel free to contact Scotts directly @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Garden
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
How do I calibrate Scotts Accugreen 2000 for pounds of Fertilizer per Sqft. What do setting equal?
To adjust calibration, do the following:
1) Adjust the micrometer setting to 6.
2) Turn the spreader over.
3) Squeeze the trigger against the handle.
4) The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper.
5) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Note: If the hopper is missing a calibration line - with the setting at 6 they should be able to pass a 9/64" drill bit through the opening just to the right of center. (First opening to the right of the spring.)
Nov 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
Garden Logo
224 people viewed this question
Top Earthway Garden Experts
lnbn1975
Madison Corley
Madison Corley
Level 1 Expert
Are you an Earthway Garden Expert? Answer questions, earn points and help others
