Question about Polaroid Televison & Video
My Polaroid TDA-03211C black screen how do i fix it or whats the problem?
    Top Expert:
  • Polaroid Master
  • 75,571 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 22, 2015
I have a Polaroid TDA 03211C 32inch LCD TV /DVD COMBO screen went black cant get screen to work,sound works
It has 2 blown capacitors in it. Mine had the same problem. The capacitors are located at EC17 & EC18 on the top circuit board inside the tv. They cost about 1.00 a piece. You can get them at DigiKey.com. It is very easy to take the board out and have someone soldier the new ones in and then put it back together. You can fix it for about 40.00. Hope this helps. Do a search on line of what the capacitors look like........
Nov 01, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
LCD screen part number for Polaroid tda-03211c
Replacing the LCD panel in any TV is not a cost efficient choice for the average person. The cost of the LCD panel is usually as much or more than the TV is worth, often times costing as much as a brand new TV. Considering the poor reputation for service that Polaroid had before it went bankrupt, it is best you consider another option since the screen is only one part of what makes the TV. Even if you were to replace the screen, you still would have a TV that was out of warranty without any service support if another part fails.
Sep 14, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen goes black
Main board. This Tv has a main board which has all the video, audio and logic chips on it. (the board on bottom with all your imputs) Have yet to see one that is repairable. www.RNS-Systems.com or E-bay about $149 for a used one.
Sep 09, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Jun 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
A owners manual for a 27 inch polaroid flat screen
google this owners manual model number: TDA-03211C
Mar 26, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Reset button on TDA 03211c
I'm not aware of any reset buttons on the newer sets, some plasma sets have one but it's only for re-setting default settings.What type of problem are you having?
Mar 04, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Televison & Video Logo
74 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
