Question about Refrigerators
The part that turns to drop the ice out of the bucket is not rotating
  • Refrigerators Master
  • 473 Answers
If you are referring to the the ice auger assembly in a dispenser type refrigerator, that unit is driven by a motor behind the ice bucket. It may be frozen up or could be completely burned out and my need replaced.
Posted on Apr 22, 2015
ifican
  • 14 Answers
SOURCE: Ice maker arm issue
If you are a real DIY'er, remove the ice maker from the frig and see if the arm has or had a spring return down or check its position with the cam that operates it as it goes around.
Posted on May 29, 2008
  • 489 Answers
SOURCE: Icemaker not making ice - feeler arm in up position
You may have a broken icemaker and needs to be replaced.  The internal parts are solid state electronics and they can break.
Posted on Sep 30, 2008
SOURCE: auger inside the ice bucket not turning - ice not dispensing
I had same problem. Fixed it by remove the motor at the back and spraying with wd40.
v_rampersad@hotmail.com
Posted on Jan 06, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Hi, I have a Whirlpool
Hi and welcome to FixYa. I am Kelly
Often ice maker issues are a symptom of an automatic defrosting problem OR a leaking (dripping / bypassing) ice maker water valve.
First off you should try and prove that there are no un-necessary water leakages by doing the following:
1. Turn the icemaker OFF
2. Remove the plastic line where it connects to the thru the cabinet water tube by pinching the clamp and pulling down on the plastic tube.
3. Place end of the plastic tube into a bucket for about 12 hours. At the end of 12 hours check the bucket for ANY water. If there is a noticable amount of water (more than 1 oz) the water valve is leaking water by the valve diaphram seat. The only remedy for this is to change the units water valve assy.
As far as a possible automatic defrosting problem..... soft ice cream is a symptom along with that of low ice production.
The evaporator coils get a substantial amount of ice build up on them and then the airflow in the freezer compartment is restricted resulting in a change in the freezer comprtment temp. If you do have an automatic defrosting problem you will soon notice noise from the evaporator fan as the ice build up encroaches into the fan blade path. Additionally the fresh food compartment will warm up.
The ice maker will not cycle until it reaches 16 to 15 deg F. The ice maker harvest cycle is started when the ice maker thermostat closes and advances the ice maker module.
Do the water in the bucket test and then look for signs of ice build up on the evaporator coils.
If neither of the above manifest / present then download this manual and follow the troubleshooting procedures:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Thanks for choosing FixYa.
Kelly
Posted on Sep 17, 2010
ZJLimited
  • 17970 Answers
SOURCE: Liebherr bio fresh fridge/freezer model
This ice maker can be cycled manually to help determine the problem. To cycle this ice maker, pull the front cover off of the ice maker. You will now have access to the module which has some test terminals marked on it (I'm sending you a picture). Using a well insulated jumper, place it between T-H and the ice maker should start to cycle.
Be careful this is a hot (live) check. If the ice maker starts, after about 5 seconds remove the jumper. It will take a few minutes for it to break the ice free and if it cycles completely and refills the ice maker will need to be replaced. This indicates it's not starting on its own. If it just stops on the ice, the mold heater may be open. You should be able to feel the bottom of the ice maker to see if it's getting warm but be careful, if you touch the mold heater, it can be very hot. If the mold heater is not hot, again the ice maker will need to be replaced. If the ice maker never cycles with the jumper, there may not be any voltage getting to the ice maker. Some voltage checks will need to be made and a technician will be needed to make these checks.
Hope this helps.
Posted on Nov 15, 2010
1 month old Samsung RF28HFEDTSR. No ice in upper ice compartment. All Ice drops to bucket in freezer section. I press reset button it dings and soon one group of ice falls in upper bucket.
I believe something's wrong with your new ice maker. Are you sure that the ice maker is not turned off on the display? And take a little bit of time and go through your user manual if you don't have the user manual let me know I will send you one
http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1509233L.pdf
Appliance 911 Sea Breeze
Sep 02, 2016 | Samsung Refrigerators
Ice bucket will not go all the way back in position. something obstructing
On the back of the ice bucket there is a round plastic piece that rotates. Grab it and turn it about a quarter of a turn then try to put the bucket back in. If it still doesnt go, turn it again. It should now line up and go in.
Mar 09, 2015 | Sub-Zero 690 Side by Side Refrigerator
Icemaker is making ice but the ice dispenser is not working
Check the ice storage container. The ice dispenser will not dispense ice until the first supply ice has dropped into the ice storage container.Remove excess ice from the back of the ice container. Make sure ice cubes are not jammed between the ice maker and the back of the ice container.
The auger won't engage or turn to dispense ice.Remove the ice bucket and with a hair dryer warm up the inside where the fork is that turns the auger in the bucket and try it and if this does not help then you will have to replace the auger motor ,, chances are the motor is just froze up .--------
If there is nothing jammed then try this./Remove the ice bin out.And then clean the ice bin.
Rotate the auger with your hand.If its hard then there is problem with auger motor.If the auger is not rotating fine then its faulty auger motor or the auger motor is frozen,if you notice ice getting collected there.
Take a hair dryer and blow hot air on the auger motor for few minutes.Take care you dont blow hot air continuously.
But if that is not helping then disconnect auger motor connecting wire wait for 2 minutes clean the connector and reconnect the connector back and see.If that is not helping at all.Then,replace the auger motor.
To see how auger motor looks.Please click the link below:---
http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=3965455&image=0
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | Frigidaire FRS26H5AS Side by Side...
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker is not working
make sure you remove the ice bucket when you press the reset button. if the ice level arm gets stuck it will not rotate. also if the rotating spindle at the back is jammed nothing will move.
Aug 02, 2008 | Samsung RS2534 Side by Side Refrigerator
Jun 18, 2008 | LG LFX25960ST Stainless Steel French Door...
Ice despenser
will it still dispense the whole cube?theres a brass rod under yourice bucket, remove bucket and check that rod, should be spring loaded and have a little bit of action(youll see it move a flap in front of bucket as its twisted, if so make sure the bucket is being reinstlled correctly, try the dispensor w/o the bucket installed at all, open the door trip the switch with one hand and depress the plunger for both crushed and cubed and check for the motor to turn
Feb 22, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
