Question about Yamaha Audio Players & Recorders
How do I hook a bsr eq-1 equalizer to a Yamaha av receiver rxv573
Seems like it should be , audio out to the eq. Then out of the eq to your sound source, ( speakers )
Posted on Apr 27, 2015
How do I connect my 901 equalizer /speakers to the yamaha rx-v633 receiver?
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 75watts per channel out of the receiver to power the 901's
Jan 03, 2015 | Yamaha Av Reciever Rx-v793 Cinema Dsp...
Yamaha rx v757 av receiver
tape out to line in on eq, line out from eq to tape in on receiver, use tape monitor switch to make eq work
Mar 14, 2014 | Audio Players & Recorders
Im trying to connect a bsr xr eq to my avr687 denon receiver
If you want the EQ to affect the iPod music only, you can hook up the iPod output to the EQ input, then the EQ output to your receiver's AUX input (or DAT input, or whatever you're using to listen to iPod music.
If you want the option of using EQ for other signals as well, then you hook up the EQ to the TAPE inputs/outputs (TAPE OUT goes to EQ input, and EQ output goes to TAPE IN)
If you hook it up this way, then you have to select MONITOR or TAPE MON to get the equalized signal.
Apr 15, 2010 | Denon Audio Players & Recorders
Eq to receiver
Connect through the tape monitor jacks and if a tape deck is used connect it to the eq! Check your owners manual if you still have it or download one.
Apr 14, 2010 | Yamaha EQ-70 Home Equalizer
I have a Yamaha HTR-5890 receiver and I am trying to hook up a Yamaha EQ-32 10 band graphic equalizer to the receiver. The frequency spectrum analyzer on the equalizer is working but the graphic...
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
Dec 29, 2009 | Yamaha HTR-5890 Receiver
How do I connect my Yamaha EQ-70 to my Yamaha RX-V2400 receiver?
from your receiver; R&L PRE OUT to R&L LINE IN of Equalizer.
And - from Equalizer R&L LINE OUT to Receiver MAIN IN.
http://www.yamaha.com/yec/customer/hookupdiagram.html?CTID=5010070.
Hope this helps!
Aug 10, 2009 | Yamaha EQ-70 Home Equalizer
How to hook up my Yamaha EQ-70 Equalizer
This is official image from Yamaha. If need to know more, go to the below address -
http://www2.yamaha.co.jp/manual/pdf/av/english/am/AV-90PY.pdf
download the amp's manual & you will find on page no. 7
Jul 05, 2009 | Yamaha EQ-70 Home Equalizer
Bose 901 Active EQ Loop
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to recieve its Active Equalization and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on my receiver it disables any digital inputs.
The good news. I have a setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W).
Run the dbx and BSR in tandem with each through the tape monitor loop on the receiver but be advised you can only use them on analog source stero material. However, you can still employ the various DSP options to spread the sound around the room.
At my PC workstation across the room I have a stack of analog processors and sources including dbx 3bx-ds, dbx 120x-ds, BSR Spatial Enhancer, BBE 462 Sonic Maximizer, SS-525x EQ, Carver C-9, dbx-224x, JVC cassette deck, Dual 1249 Turntable running through a Garrard MRM-101 Preamp, Pioneer PDR-509 CD Recorder and the Media Center PC stereo analog channels all running through a dbx 400x Program Route Selector (a godsend) which is attached to my ONE TAPE MONITOR on my Pioneer VSX-36TX Receiver. Of course, I have some of my analog processors running in tandem, too, since the 224x only has three processor and three tape loops.
For listening/recording anything 2-channel analog I engage the stack through the Tape Monitor. For everything else I turn the Tape Monitor off. The nice thing about the stack being separate is that I can doodle with recording and use headphones while the TV/DVD/Blu-Ray do something else.
Jan 10, 2009 | Onkyo TX-SR705 Receiver
I need to connect an equalizer (EQ-70) to a Yamaha RX-461 AV receiver which plays a Bose Acoustimass 6 Home theatre system. The Receiver does not have a tape deck. So ow do I go about it?
If your receiver has a TAPE IN you can connect the EQ to that, and it will work just fine. Or if you have main LINE OUT / LINE IN, you can create your loop there.
- OPTiC
Equipment Repair & Service
A DJ Pro Audio Co.
Dec 17, 2008 | Yamaha EQ-70 Home Equalizer
Gemini Sound Products EQ-3000 equalizer
please connect as the following-----1-mp3 out-----to cd in in your receiver.
2-receiver rec out (tape put)----to equalizer in.
3-equalizer out----to tape in in receiver.
Sep 17, 2008 | Gemini Sound Products EQ-300 Home...
418 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
