Wont switch to cooling when thermostat is switched blows hot air
  • William Goodman
    William Goodman Apr 22, 2015
    What kind who what where :) model num mnufcturer nd what are wr working on?
    Habit-Forming:
    New Friend:
  • 42 Answers
Is the knob stripped?
Posted on Apr 22, 2015
  • 263 Answers
SOURCE: Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Posted on Dec 31, 2007
  • 958 Answers
SOURCE: RobertShaw Thermostat 9600 problem
verify if you have separate units for each floor.
the ones working could be a complete separate unit from the one having problem.
look at the condensing units you got outside , how many are there?
if you have 3 units outside and you have 3 thermostats, then each thermostat is controlling individual split units.
we have to concentrate on the one that is not cooling. give me the details on what is going on with problematic one.
is the outside unit running?
is the outside fan running?
can you distinguished if the compressor is running the same time as the fan?
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
diths_kri
  • 67 Answers
SOURCE: furnace blowing cold air
THERMO
Posted on Jan 07, 2009
  • 659 Answers
SOURCE: wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Posted on Apr 01, 2009
mcgyver468
  • 710 Answers
SOURCE: Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Posted on Apr 27, 2009
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
Armstrong Ultra SX 80 Central Unit won't kick off heat setting
From what you describe it sounds like it might be a relay problem.
It needs to be diagnosed properly first.
Apr 21, 2017 | Heating & Cooling
2004 chevy Impala my heater and my air conditioner wont blow air
start with using a meter to test for power start from fan back to switches need to check harness and connectors
Nov 02, 2017 | 2004 Chevrolet Impala
1999 Ford F150 AC fully charged with freon is blowing hot air
there are few things you need to check out:
1. if the compressor is overcharged it will shut down and you won't get any cool air
2. the thermostat for your cooling system is bad
3. the link to adjust the temperature is too short (did you feel the switch loose when changing temperature from hot to cold)?
hope this helps.
Jun 06, 2010 | 1999 Ford F150 Regular Cab
What's going on -- Vents are blowing hot air and
It sounds like the unit is stuck in the heat mode or the thermostat switch is still on heat. If the switch is in cool then you can go to the outside unit and locate the reversing valve. It may be stuck in the heat position. You can tap it with the handle of a screwdriver but only on the ends and very lightly because if you dent it the valve will be stuck for sure. If it shifts you will hear a loud hiss as the pressure equalizes. You could also try unplugging it from the circuit board. On some units it is energized in the cool mode and on others it is energized in the heat mode.
Jun 05, 2010 | Whirlwind FH-778 Air Conditioner
I just purchased a honewell RTH 221 thermostat. I
Typically the four thermostat wires are:
R = power (or common)
G= FAN
W = Heat
Y = Cool
Assuming that you have a normal electric or gas furnace and air conditioning, if the heat really is coming on, then just switch the position of the the Yellow and White wires.
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
97 Ford Econoline air conditioning and vent settings blowing hot
I know from experience that if the coolant is to low ( not just the freon levels in the compresor but the antifreeze/coolant level as well) the AC system will not cool and will blow hot. Check the coolant Antifreeze and freon levels, even with the Coolant being a little low my 1998 Ford E150 Van will blow hot. After you have ruled out of these possibilities and the chance it is the thermostat most likely the problem is what Ford calls the "Flap" it controls the air flow through the vent system when you switch from Heat to AC. When the Flap is working it closes off one systems air flow so as to not interfere with the current climate selection.
Feb 21, 2009 | 1997 Ford Econoline
A/c and heater
Is it leaking antefreeze?
The thermostat might be gone or needs a bigger thermostat
It could be a vaccum leak for the drivers side blowing cool air and the passenger side blowing warm air
Does it have dual air control switches one for drivers side and one for passengers side?
Oct 28, 2008 | 2003 Pontiac Grand Prix
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
