Heater will not light- spark is visible - Heating & Cooling
    Top Expert:
  • Heating & Co... Master
  • 52,097 Answers
We do not know the make model of that heater but most you need to push in and hold the pilot button till it lights and hold for a few seconds till the main burner will come on
Posted on Apr 22, 2015
No spark visible through mica glass inspection cover when piezo igniter button is operated.
Piezo igniters can fail for a few reasons. Often they short or spark in the wrong place. Sometimes they can be corroded. Try cleaning it and see if it will spark. Otherwise, you might need to replace it or just use matches. Is your heater under warranty?
Jun 11, 2015 | Water Heaters
My 1999 Chevy Suburban K1500 cranks; but will not start.
You have to determine whether there is no fuel supply or no spark supply. Disconnect one plug wire and ground it to the engine and crank the vehicle. There should be a visible spark and snapping heard. If spark ok check fuel pressure on the fuel rail with a guage. Should be 55-60lbs.
Apr 11, 2015 | Cars & Trucks
Pilot light wont light will spark, but no propane
verify the inlet pressure to the heater. those pezioelectric spark lighters are garbage. make sure all manual shut off valves to the heater are open. Pilot tubing may also be blocked
Nov 25, 2013 | Glo-warm 503284 30000 BTU Propane Gas Vent...
GE furnace pilot won't ignite
Check for 24 volts at the pilot valve on the gas valve, if there is voltage, take an amp reading, if you get amperage it's trying to work, see if pilot orifice is obstructed by webs etc. very common to see this.
Oct 31, 2012 | Heating & Cooling
I have a Dyna Glo-pro multi fuel heater. When I turn it on the ingitor starts working and than the fan comes on for a few seconds. Then the system shuts down because it willnot ignite. The tank is full and...
Since it does not ignite, Please check the ignition transformer. This have a secondary voltage of about 20,000 to 25,000 volts, enough to make your igniter
spark, thus, causing the atomized fuel to ignite and burn the fuel. So, please include igniter high voltage cable for ground leak. Ground leak is visible as line sparks when your heater is switched on. If your ignition transformer does not produce sparks at the
igniter, it means it needs to be replaced.
Have it done to make it work. Hope this will help you.
Jan 10, 2010 | Dyna-Glo RMC-8001SS Heater
OVERHEATING, CONSTANTLY FILLING RADIATOR WITH ANTIFREEZE AND NO VISIBLE EVIDENCE OF LEAK, CHECK ENGINE LIGHT ON, DIAGNOSTIC TEST SAYS 3RD CYLINDER IS MIS FIRING, HEATER QUIT WORKING
Check the exhaust for white smoke. Also, while the car is running, check the oil dipstick. If the oil on the dipstick is frothy like a milkshake, this along with the white smoke are indicators of a blown head gasket.
Jun 29, 2009 | 2001 Chevrolet Malibu
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Ignition
This is a "probably". The reset button trips because the photocell fails to see a flame in the combustion chamber. That's its job.
Check the ignition device ( transformer, coil). See if 110v going in. If there is no spark coming out, replace it.
Troubleshooting tips
Jan 10, 2009 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
