Problem for PC Laptops
Generic problem for all PC Laptops
WinXP SP2 not detecting bluetooth device
I have an Acer Travelmate 5620 notebook. It originally came with Windows Vista loaded. The LED buttons for W/LAN and Bluetooth worked fine and the bluetooth device appeared in my Device Manager. I even connected my cellphone successfully via bluetooth.
After formatting and installing Windows XP with SP2, neither LED button works, my bluetooth device is not detected (it does not appear under device manager and I have no 'unknown device' listed here either). I've installed the latest Widcomm bluetooth software that I got from the Acer support site specifically for this notebook and WinXP, but when I click the blue/red icon in the taskbar, all I get is 'no bluetooth devices'. I know I have the hardware as it used to work before I formatted!!! I've spent hours, trying all kinds of tweaks and software. There is nothing in my Bios that allows me to enable/disable devices.
I've come across other threads of people with the same kind of problem (WinXP SP2 not detecting integrated bluetooth), but no solution yet. I think that if I can get those 2 buttons working, then I'd be able to at least turn the bluetooth device 'on' so that windows would detect it and I could point it to the drivers...
Also, the ePowerManagement does not work with dot net framework 2.0+ installed (all features are disabled). That worked fine with Dot Net Framework 1.1, but I need 2.0 installed (else SQL Server 2005 doesn't install....). ePower Management used to allow me to enable my bluetooth, then it worked 100%.
Please, anyone who can help, I'd be most grateful.
Comments:
Nov 14, 2007
- I tried those right from the start
They install the Bluetooth Bus Enumerator. But complain during install that no bluetooth device could be detected. I've reinstalled I don't know how many times already, redownloaded to make sure I've got the latest versions (the Vista ones won't let you install, I've tried those even out of sheer desparation.
But I think I may have just found the solution :-)
I came across a post a few minutes ago on another site saying I should install the Acer Launch Manager before installing the bluetooth drivers. Well, I uninstalled anything resembling bluetooth, rebooted. Installed Launch Mananger 1 from the Acer site. Rebooted just to be safe. Now my LED buttons (Bluetooth and W/LAN) both work. The bluetooth drivers installed and detected the bluetooth device. I've even got my phone connected now :-) Seems you have to do this in that specific order else the bluetooth doesn't work... I've had Launch Manager installed before with no success, but only after the bluetooth drivers were already installed and not working...
So thank you for your help. All is finally 100%
Same Problem
Apr 15, 2009
-   when I click on 'My Bluetooth Connections' on my Lenevo laptop,it is not detecting any device in range.When I switch on my bluetooth from my cell phone,then also it shows themessage that 'no bluetooth devices found'.-
PRIU Feb 25, 2009
-   i keeps cimmin up NO BLUETOOTH DEVICE
-   Guest Jan 18, 2009
-   my acer 6930g can't detect bluetooth,what i should do?
http://www.part.lt/p-e48a60e48ad376f7c581b29f35f03005892.JPG
gasasasas Dec 04, 2008
-   My Sony VAIO VGN-SZ460N/C PC notebook does not recognise my Nokia bluetooth stereo headphones.
thrillbill Jun 14, 2008
-   i hv Acer Aspire 1642WLMi and it has bluetooth which windows XP connot detecting and may be some drivers are lost or deleted from my notebook so kindly help to find it out or i need some recovery cd which is lost -
pappubhai
Best Solution
posted on Nov 14, 2007
Rank: Wiz
Rating: 83%, 52 votes
go here
http://support.acer-euro.com/drivers/notebook/tm_5620.html
in top window choose bluetooth_5.0.1.1500
download file and save to desktop
then run it
Hopfully that will work for you
Comments:
Nov 14, 2007
- the actual file you will be downloading is named >> bluetooth_5.0.1.1500.zipNov 14, 2007
- what has happened is the windows vista drivers are not right for the win xp Operating system so at that site you will need any drivers for other items that aren't working now also
Was this helpful?1 person thought this was helpful
Solution #2
posted on Apr 15, 2009
Rank: Wiz
Rating: 87%, 25 votes
uninstall the bluetooth driver from your pc and then reinstall it.
reboot your system after installing the driver.
now you are able to connect the the device.
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
what is the problem of my HP laptop is going to blink2x his display in screen?
How to choose a ebook reader.Comparison of performances between different models
How do I turn bluetooth on in L300D Toshiba laptop
Hi there! I have a big problem with my ASUS W3J! First of all my problems starts with that I turned...
(More)
Hi there! I have a big problem with my ASUS W3J! First of all my problems starts with that I turned on my laptop and the screen doesnt turned on, I only heard the sound when my laptop turned on, then I turned of and try many times like 5 till 10 and in this time I remove battery and close the lid and than after couple times it turned on and everythink works fine. Sometimes the screen turned on at the first time, sometimes it doesnt, only after some 5 times... Soo but after some 3 months my laptop starts working very slowly and I decide to reinstall windows. First of all I cant install vista and windows 7 because my BIOS version ir 207 which doeasnt allow me to install Vista or Windows 7 . So I turned on My ASUS W3J and its turned on and when windows xp turned on after some 5 minutes everything breezed I cant move mouse cursor and I cant do anythink - yhan I turned off my ASUS and restart, than he show me some error on windows screen everythink goes fine after that and than again I cant do anythink... When I bought this ASUS W3J it comes with windows XP Profesional reccovery CD - so I tried to recover windows (I did it before with this laptop and it works fine). Than he ask me to "please press any key to load from cd" or somethink like that, I press enter, than he ask me "what I wanted to do" and give me a 4 options - I chose 4 option to make a C and D disks, so than he ask "do I realy want to recover" - I chose Yes, than He ask "do I need to start recover?" I press Yes and he start to recover process after some 15 minutes or maybe 10 I saw that he hang on I cant do nothink it just stand on 25 % amd thats it.. I wait about 20 minutes - he dont do nothing and I turned off laptop, than turned on and when I want to stat again recover he show me tha error report that "failed to boot C" or something like that and just show black screen with comand log... when I start normal my laptop to go to windows he show me that: "please chose some different multimedia device or something like that.. and do nothing... please help me what happening with my ASUS W3J why I cant recover windows (what I did many times and follow manual instruction)? Do my hdd is broken or maybe my video card ir also broken or some video card drivers are broken, because he also once show me the error, that some problem with my video card or video card driver... but it was only once on all 3 years when I have this laptop only on the same day when all that nightmare happens. My laptop newer falls down from table or somethink like that! Please help and maybe give me some advice whats going on, because I dont have no idea! Thanks a lot Best regards walters
I have hp mini netbook and want to connect with my hp laserjet 3050 printer. i coulnt`connect tried...
(More)
I have hp mini netbook and want to connect with my hp laserjet 3050 printer. i coulnt`connect tried to download software but wanted `hpzpp4wm.dll file
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 16, 2008
CANNOT LOCATE THE BLUETOOTH, LAPTOP STATES NO DEVICE
Comment by question82, posted on Apr 22, 2008
WinXP SP2 not detecting bluetooth device for hp pavilion dv4000 please help me soon
