Question about Garden
I have a jd170 and as soon as I hit the pto switch the mower dies I just replaced the $40 pto switch and that's not the problem
  • 2 more comments
  • Lee Plouck
    Lee Plouck Apr 21, 2015
    The seat switch was already removed when I bought it! Mower ran great last year plowed snow all winter and now put the deck back on and went to mow and ran into this issue! Had to push the hole yard last week!!!!!
  • Lee Plouck
    Mower also does this without the deck on!
  •  johnny rebel
    johnny rebel Apr 21, 2015
    check your ignition switch,pull the plug off the back,look for rusted or corroded connections,and burned connections,a new ign switch may be needed
  •  johnny rebel
    i hate this,i live 3 miles from where john deere had his tractors in proctor vt and i cant find a single owners manual for free!
    Top Expert:
  • 10,875 Answers
If the blades turn freely then you are going to have to replace the pto or ignition switch,take the drive belt off,does the pto work?,if not,it is electrical,check switch then pto,then pto safety switch
Posted on Apr 21, 2015
  • 4 more comments
  • Lee Plouck
    Yes blades turn freely just replaced the pto switch and jumperd the clutch switch (not sure if u can do that but did) and still kills the engine
  • Lee Plouck
    Lee Plouck Apr 22, 2015
    wires and terminals look good juiced em down and engine dies even with belt for deck off
  • Eugene Rounds Apr 22, 2015
    Check your operator seat switch and its connections.
  •  johnny rebel
    johnny rebel Apr 22, 2015
    your pto is binding up,take it off and check the bearings,use 12 volts to help determine if it is working correct
  • Lee Plouck
    Seat switch was disconnected when I bought it last year n ran n mowed fine last year
    On the back of the PTO switch there should be a gray wire. Disconnect it and test.
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
  • 153 Answers
SOURCE: When I engage the front PTO the engine dies.
There is somthing in the PTO that is binding up. I am assuming the PTO is for the mower blades. The belt(s) could be binding up, not on the pulleys, etc. The blades should turn by hand easily.
Posted on Oct 14, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
huffman49
  • 235 Answers
SOURCE: Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Posted on Apr 03, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
As soon as ignition key is turned to run PTO engages
check your pto switch with a test light turn pto switch to off take T/ light ground it good turn ignition on and if light comes on you have a bad pto switch
Mar 17, 2014 | Garden
LX279 dies as soon as you let off brake
This sounds like a safety switch on brake linkage. Just as there is a safety switch on seats of riding mowers, there is also safety switches for brakes, pto, etc. I would look for switch on brake linkage and test with a multimeter for continuity. Hope this helps.
Aug 09, 2013 | John Deere Garden
Ariens zoom 1640
you have a bad safty swicth probably the pto safty swicth for reverse
Jul 20, 2013 | Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
Eletric PTO is not working
The PTO draws a pretty good current, so a weak or loose contact in the switch, or in the connections on the back of the switch, could cause this overheating. But it could also happen if the PTO clutch itself or the wiring to it has a short. If the mower's still under warranty, get the dealer to diagnose and fix it. If not, then I'd measure the resistance of the PTO clutch - should be about 2 ohms - and make sure the wiring to it isn't shorted. If all that is OK, then just replace the PTO switch and any melted connectors and wiring. Good luck!
Jul 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Engine dies when engaging PTO switch on a John Deere GT235. I have replaced the seat switch and the PTO switch.
Feb 21, 2009 | Garden
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
