Question about Kwikset Locks & Locksmithing
Where is the power strip on the Kwikset power bolt?
    Guru:
  • 147 Answers
8. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
Remove inner cover plate located above the thumb turn on the inside of the door. Click here to view instructions on how to remove cover.
Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
Ensure that the batteries are correctly oriented or unit will not function properly.
Posted on Jul 02, 2015
Are there shorter latch bolts for kwikset locks
You may need to drill the hole in the frame deeper to prevent the bolt from bottoming.
Sep 21, 2014 | Kwikset Locks & Locksmithing
I Have a new Kwikset 909 LO3 SMT CP unit - How do I change door handedness?
In section 8 of your instructions is the "Door handing" programming instructions
Link here: http://s7d5.scene7.com/is/content/BDHHI/Website%20Content/Kwikset/Resources/KwiksetSmartCodeManual.pdf
You need to carefully go through this programming routine without interruption. That should fix it for you. Good luck!
Jul 05, 2012 | Kwikset 907 L03 Smt Cp Powerbolt
When locking or unlocking using the power it attempts to over throw the bolt 3 times which produces a clicking sound. Deadbolt works fine with key and does this when unobstructed with door open even.
This sounds like an unusual problem, but your lock may be covered under warranty. Warranty covers mechanical and finish defects, but not the internal electronics. I recommend calling them-- call 1-800-327-LOCK (5625) in the U.S. and Canada.
Here is a link to Kwikset's website for your reference, and you can follow a link to their written warranty, etc.:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Aug 15, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
None of the buttons on the device will work. Batteries are fine and blinking light inside appears normal. Cannont lock the device from outside or get the code to unlock the door.
Check to be sure the keypad is still connected to the inside assembly. There is only a one year warranty on the electronics and Kwikset will not sell the electronic parts separately. If you want to replace it, there are other brands that are key-compatible with Kwikset. You'll still have the same problem if the electronics breaks though. The main difference is that other brands don't move the bolt with battery power, they just enable it to be moved by hand.
Aug 06, 2011 | Kwikset 909 909-L03 Lifetime Polished...
After replacing the batteries, my lock starts with the alarm beeping and won't stop. this is the second one that has done this. what im i doing wrong? or are they only good for one set of batteries?
There is only a one year warranty on the electronics and Kwikset will not sell the electronic parts separately. Check the installation manual for a reset procedure - basically the lock might be "forgetting" it's programming. Another possibility is that it's trying to move the bolt and can't. Be sure the bolt moves freely.
If the electronics have failed and it's out of warranty, there are other brands that are key-compatible with Kwikset. You'll still have the same problem if the electronics breaks though. The main difference is that other brands don't move the bolt with battery power, they just enable it to be moved by hand.
Aug 06, 2011 | Deadbolt Kwikset 907 Smart Code Polish...
Dead bolt does not align with the keypad, every time i turn the dead bolt it only goes in so far then i hear a click, and if i push the lock button it doesnt turn i hear a continuous click then the keys...
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Apr 16, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The bolt will not move via the power, it does move manually. i also put new batteries in.
Kwikset's warranty covers one year electronics defects and lifetime coverage for the mechanical movement and finish.
Here is a link to it:
You can contact them from there for further assistance.
Sep 28, 2010 | Kwikset UltraMax Powerbolt 1000
I have installed the Kwikset set smartcode, while it operates correctly while the door is open, when I close it it will beep every 30 seconds, I measured the precut hole for the bolt and it is 11/16 th...
Why is my Powerbolt beeping?
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Good luck--and please provide feedback if this helps!
Sep 23, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Near new lock not functioning
i had the same problem. i called the company and they told me it was toast. if yours is fairly new, they should replace it for free. they will need some numbers of your lock so they can tell how old it is. if they will not fix it, i recommend getting a schlage be365, that is what i got when my kwikset quit working. i love it, and the batteries in it last a very long time because the power to turn the bolt is your hand, not a motor.
Oct 15, 2008 | Kwikset 907 907-L03 Lifetime Polished...
Locks & Locksmithing Logo
747 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
