Question about Whirlpool Gold GSS26C4XXY 26.4 cu. ft. Side by Side Refrigerator with MicroEtch Spill Control Glass Shelves, In-Door-Ice Plus, External Ice/Water Dispenser, 6th Sense Technology and CEE Tier II Energy Star: Monochromatic Stainless Steel
How do I fix the water that is coming out of the water filter area?
We just replaced the air filter as well as the water filter but water is streaming out of the water filter area? what can be the problem?
    Top Expert:
  • Whirlpool Master
  • 42,778 Answers
Didn't get it seated properly possibly or a line busted
Posted on May 05, 2015
Fan on air cleaner blows out top but does not suck
If air is blowing out - it most assuredly is getting in. The area of the intake make be large enough for you to perceive air being sucked in.
Make sure ALL filters are clean. Remove and replace disposable filters or wash and replace permanent filters. Do this for pre-filters too. Then, try again.
Oct 23, 2015 | Hunter 30200 Air Cleaner Purifier Filter...
Overheating
After replacing or refurnish engines head is recommended to replace water pump and inspect thermostat, radiator, and cooling fan. Most of the time engines overheat is because there is not enough water circulation thru the head due to malfunctioning water pump, radiator, thermostat and or radiator's cooling fan. By just fixing the damaged head you may not be solving the problem that originally burned your head gasket.
Apr 03, 2014 | Spectre 2001 Audi A3 - 1.8L 4-cyl. engine...
There are 2 holes on underside of filter housing & when turn on filter water , out both holes, why I hate running it as you don't know if you are getting filtered water from both holes.Help
The main problems I'm seeing on these posts for this filter are design and operater issues. 1. I never run hot water through the unit in filter mode. 2. I never run cold water through the filter turned on high (pressure issues arise), it doesn't filter the water any faster. You just want enough flow to run through the filter. 3. The steel sleeve was a good solution (again pressure) but came up alittle short (ie my epoxy fix). 4. The light is powered by a chip batterey that is unreplaceable and may be bad. Try reinstalling the cartridge. I personally pay no attention to the lights other than a clue. I change my filter when the taste changes or there becomes a flow issue. 5.There are filter screens prior the filter that can become clogged if you live in a poor water area. 6. The filtered water only comes out of the spigot and no other leaks (something loose or pressure issue).
Sep 30, 2013 | PUR (FM-9500) Air Purifier
Where and how can I order new filters.
You never need to ORDER new filters for your SUN AIRE purifier unit. Our pre-filter is LIFETIME/WASHABLE 0.5 micron 2-stage electro-static and NEVER needs replacement. Our pre-filter saves you about $100-200 per year in expensive replacement HEPA/charcoal/carbon filters on other units. Made in America and built to last you a lifetime- SUN AIRE purifiers! www.betterair.com
May 04, 2010 | Sun Aire Sun-Aire Air Purifier - Stainless...
How do i clean black honeycomb filter inside fan area?
Put filter in bathtub, or sink if it'll fit, and swish it in the moderately hot soapy water, use can use dish soap. Then rinse off with moderately hot water but not scalding, then tamp it off onto a towel to get as much water off of it as you can. Your supposed to then let it dry for a while before reuse.
Mar 05, 2010 | Brookstone Pure-Ion UV Air Purifier
I HAVE A RAINSOFT UV AIR FILTER IN MY AIR DUCT WHERE DO I GET REPLACEMENT BULBS, AND WHAT IS THE PROPER BULB AND SIZE?
Cleanwater also has them. Clean them with rubbing alcohol, do not let your fingers touch the bulbs. And check your 24V ac adapter. If it starts going you will get a power light but the other lights will come and go. I have one and the bulbs are nearing the end of life, not a cheap fix.
http://www.cleanwaterstore.com/O1002250-p-clearwater-tech-parts.html
Jan 02, 2010 | Air Purifiers
Do you have to replace the filter each year at start up?
no .. there is no replacable filter .. you do have to clean the housing and disk stack .. the motor assembly comes out easily so you can clean things ... kind of nice 10 warranty with that ... follow instructions for water ..
Oct 05, 2009 | Venta - Airwasher LW44 Air Purifier
Defender air purifier
If you have replaced your main filter you need to reset the red light. If you have not replaced the main filter you will need to contact your local filterqueen distributor. If you go to www.filterqueen.com they will direct you to your closest distributor and they can walk you through over the phone on how to reset your red light.
Feb 15, 2008 | Filter Queen Defender Air Purifier
Air Purifier smells like chlorine
Mine does too. Did a little research - I guess all air filters let out a little bit of ozone. Some describe the smell of ozone to be something like bleach yet others say it smells like geraniums or even "sparks" (like the sparks that come off of the bumper car ride at the fair...hmm...interesting). Not sure which to believe, but I know mine smells.
I found a manual talking about reducing this smell. Said the first couple of weeks are the worst of it, but if it still bothers you, you could install an "activiated carbon filter" down stream from the air filter, or go through complicated instructions (for whatever model they were talking about) to go into the of the machine and switch stuff around.
Both solutionssound complicated to me.
I'm just happy knowing the smell is normal and that it is actually working. Think I'll live with the smell.
Dec 13, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
Whirlpool Gold GSS26C4XXY 26.4 cu. ft. Side by Side Refrigerator with MicroEtch Spill Control Glass Shelves, In-Door-Ice Plus, External Ice/Water Dispenser, 6th Sense Technology and CEE Tier II Energy Star: Monochromatic Stainless Steel Logo
345 people viewed this question
Top Whirlpool Air Purifiers Experts
mike cooper
ray gallant
Jerry Kramer
Jerry Kramer
Are you a Whirlpool Air Purifier Expert? Answer questions, earn points and help others
