Question about Homelite Garden
My homelite 2700 psi pressure washer model ut80993f is leaking oil from what looks like the head cover anyone know what to do?
  • Homelite Master
  • 1,169 Answers
Thanks for posting the model number this help to look your equipment.
You need to remove the cover that is on the Honda GCV160 clean the mating surfaces and reseal the cover. Honda specs applying Three Bond 1207 or its equal and reinstalling the cover.
Posted on Apr 22, 2015
  • 10 Answers
SOURCE: Oil leaking from pump
top is a breather you may be overfull of oil most pumps you can use engine oil .drain and put in half litre or if it has a sight glass top up to low side of glass and try it out.possible your seals on way out this usually then leaks at front or gets water in.if you still have good pressure oil seals easy to do.
Posted on Apr 21, 2009
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
  • 5603 Answers
SOURCE: pressure washer lost pressure in the middle of a job
The pressure valve has stuck in the high pressure position. This prevents anymore inflow and hence no further water will be pumped.
Rebuild the valve... There are O Rings to replace and clean the bore with croocus cloth. Lube the O rings with plumber's grease... good as new! 15 minute job. Get EXACT sized O rings for the unit.
Posted on May 16, 2010
SOURCE: My Durabuilt DB1303 pressure washer leaked oil. I
where do you find parts for your power washer? I have durbilt DB1303 and the adjustable spray nozzle started leaking, i look in my owners manual and the the wed site goes to some 3rd praty site that is not helpful. and the 800# they have in the manual you have to leave a message, so does any know where to get parts please help
Posted on May 24, 2010
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Why detergeant for homelite 2700 pressure washer only works with blue tip?
The chem venturi relys on low pressure to function this is specifically the blue nozzles job, to create a low pressure for the venturi to work.
otherwise you will be wasting chemical the entire time you are using the cleaner.
Hope this helps:)
Brad
Jul 14, 2014 | Homelite For Excell - Pressure Washer Pump...
Why can't I get pressure
Bypass valve may be stuck open bypassing the pressure.
www.homelite.com/service_support
Jun 23, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
May 14, 2014 | Homelite For Husky - Pressure Washer Pump...
Excell pressure washer
What is your model #
http://www.ppe-pressure-washer-parts.com/excell-devilbiss-pressure-washer-replacement-pump-parts
Nov 03, 2013 | Homelite For Excell - Pressure Washer Pump...
Where is the oil drain plug located on a Homelite 2700 psi 2.3 GPM Honda Gas Pressure Washer?
There is drain plug, surprisingly. You basically have to tip the washer over to the side opposite of the exhaust. I like to take the wheel off first. It is much easier this way. You don't want oil to get in the exhaust Or you could get something like a turkey baster and pull it out. There isnt much oil in there so it isn't that difficult.
Let me know if you need more assistance.
Travis
Jun 06, 2013 | Homelite Ut80993 Honda Gas Pressure Washer
Oil runs out under flywheel when motor starts honda GCV 160
Your top seal on the mower motor is faulty...replace with new seal...
Mar 25, 2013 | Homelite For Husky - Pressure Washer Pump...
Garden Logo
226 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
