Question about Proscan Televison & Video
Fix antenna jack on proscan tv that came out on the side of the tv
    Top Expert:
  • Proscan Master
  • 45,384 Answers
Repair shop time
Posted on Dec 20, 2015
My proscan tv cannot find channels in channel auto scan?
There has to be sufficient signal strength for channels to be detected. There may be a missing or poor antenna connection or an inadequate antenna.
Mar 06, 2017 | Proscan Televison & Video
I hooked up my new Proscan TV to the antenna but it can't find any channels
You need to check the connection is tight from the antenna and also on the back of the tv. You may need to try another coaxial cable. Is your antenna powered, meaning does it have a power plug that needs to be plugged in? Is your tv an old crt television? You may need a converter box to be able to view digital channels. A signal booster may help you get more channels.
Your tv or antenna may be defective. You could try your antenna on another tv. If your other tv gets a signal, your tv's tuner could be bad. If the other tv goes not get a signal either your antenna could be bad. I hope this helps narrow down your problem.
Oct 22, 2016 | Proscan Televison & Video
How to fit a sound bar to a proscan tv
1) Go the Sound Tab on the remote's Proscan menu
2) Set the system's "Digital Audio Output" to PCM (pulse code modulation)
3) Connect a coaxial cable from the Coaxial "jack" on the back of the TV to the Digital Input "jack" on the back of the sound bar.
It should work now!
Feb 05, 2015 | Proscan Televison & Video
What is rf jack on proscan tv
The rf (radio frecuency) jack is the plug for connect the antenna
Sep 07, 2014 | Proscan Televison & Video
My 16 year old son found a Proscan 19LB30QD on the side of the road (good old country living) anyway, it has not plugs, it is probably broke, but we thought we'd give it a try and see if it works. ...
Do you mean that the unit has no power cord or is the TV missing the input board from the side? Sears Parts Direct has parts for the Proscan 19LB30QD here: http://www.searspartsdirect.com/partsdirect/part-model/Proscan-Parts/Television-Parts/Model-19LB30QD/3027/0333300/50036238/00001?blt=06&prst=0&shdMod=19LB30QD . The AC cable is PART NUMBER: E080515H00 for $27. There is also an adapter, PART NUMBER: E075WDN1, for $26.79. The input board is part 6 on the diagram (main board).
Other cords will depend on what you want to connect to the TV. There is 1 HDMI port for connecting a set top box, component, composite and S-video jacks (for other set top boxes), a VGA port and a coaxial (antenna jack). Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/19678/PROSCAN-TV-VCR-or-DVD-Combo-L0807673?brand_name_search=fall+back .
I hope this helps.
Oct 06, 2011 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
My tv keeps going to no signal
I take it you have no cable or dish. If this is the case put your antenna out side or for best results use a roof type antenna. You may have metal siding on your house.
Sep 02, 2010 | Proscan Televison & Video
My proscan 32LB30QD won't power up. It worked
try this first:
Setup and Connection
The TV won't turn on Check your power cable connection.
• t can't view the Basic channels. Check the connection of the antenna cable
• t want to view cable channels. Register with your local cable company then connect their receiver to your TV.
• t want to view satellite channels. Setup your Satellite parabola antenna then connect your satellite receiver to the TV.
• Digital broadcasting is not functioning Check your antenna cable connection. Check if the digital channel selection is correctly
connected to your antenna cable.
Jun 15, 2010 | Proscan 32LB30QD 32 in. LCD TV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
Jul 01, 2009 | Proscan 32LB30QD 32 in. LCD TV
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
May 15, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
