Question about Cub Cadet Garden
I have a 2009 cub cadet 1050 ltx. Just replaced hex bushing and gear on stearing column. Still not engaging sprocket to turn wheels.
    New Friend:
  • 197 Answers
Probably need a new steering shaft and gear.
Posted on Jun 02, 2016
5 Suggested Answers
SOURCE: Cub cadet LTX 1045 steering problem......... Only
Probably a bent "drag link". See your owner's manual about checking for damage adjusting the steering. For the LTX 1045, it is "Maintenance Section 6", Page 22. If it is bent, repair or replace as mowerman1857 indicated.
You should also lubricate at the two grease fittings (per side) shown on Page 20 -Lubrication - "with a #2 weight Multi-purpose grease". It may have been skipped at the factory or may have been stored at high temperature before you got it, and dried out. (Text in quotes are from the manual)
Posted on Nov 01, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
SOURCE: cub cadet LTX 1045. The PTO cable came off the
how does p t o cable go on a ltx 1045 cub cadet
Posted on Aug 31, 2011
  • 6468 Answers
SOURCE: Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Posted on Aug 15, 2012
Ltx 1050 model 13rf91ap056 starter spins but gear wont pop up to engage flywheel
not sure of your vehicle but sounds like Bendix has gone, you need a new starter, or recondition it
Apr 24, 2016 | Cub Cadet Riding Lawn Garden Tractor 25hp...
How to make gears/teeth on lower part of steering line up on 268-H T Wheel Horse line up? Rmove deck, orwhat? There is some wear on the teeth, & was bumping last time I mowed. Now, won't turn at all.
There is a spacer/bushing on the very bottom of the steering column. With wear the bushing fails and lets the steering column/and gear on the bottom of it slip down to the point that the gears don't mesh. Replace the Bushing.
Sep 14, 2015 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    www.georgiamower.com/cub-cadet-ltx-1046kw-2014
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Jul 31, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Cub Cadet LTX 1050 50 inch. How do I get the deck belt over the PTO?
A common problem:
Make sure that:
1) You have the right belt if it's a replacement.
2) The mower control is in the "DO NOT CUT" or "NOT ENGAGED" position.
3) The tension idler has fully retracted.
Jul 18, 2015 | Cub Cadet Garden
Will a wiring harness from a ltx 1045 fit a ltx 1050
Since the LTX1050 has an electric PTO and the LTX 1045 has a manual PTO then I would say no.
May 10, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
Ivibrates when i put it in gear
If it vibrates when blades are engaged then blade balance or belt alignment is a problem. If without blade but just moving, then a problem with the transmission. Warranty? follow that path.
Apr 04, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
Have a 2009 cub cadet LTX 1050 VT. Wont start. Have checked the spark and fuel from tank to carb. Motor turns over but will not fire. can anyone help?
If it's an OHV engine you could have a valve out of adjustment(not opening) or a bad sparkplug,or a plug main jet in the carb (clean carb).
Oct 13, 2014 | Garden
Oil light on ltx 1050 cmes on after starting engine but it's full of oil
oil light indicate oil PRESSURE not volume... replace the filter which may be blocking oil flow, and then see about replacing the oil pump
Jul 04, 2014 | Cub Cadet 2011 - LTX 1050 - 22 HP Kawasaki...
Ssteer turns to left but not to the right the grears look a lil used but other than that ok
Had the same problem with my GT1554. There's a hex shaped bushing with a round center that the steering column passes through, found immediately above the gear on the steering shaft, on the top side of the sheet metal. It had worn to an oblong opening and allowed the gear teeth to slip past each other. Replace that bushing. Even if there's a little wear on the teeth, they'll mesh OK after the bushing is replaced.
Sep 08, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Garden Logo
95 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
