Question about Universal Televison & Video
How to do a channel scan with my get universal remote
  • Universal Master
  • 5,631 Answers
I couldn't find any GET remote, so presumme it's GE Look at this website.
GE Universal Remote Codes Jasco
Posted on May 09, 2015
3 Suggested Answers
  • 39083 Answers
SOURCE: How do I get my GE universal remote to scan my
Your GE universal remote should have a code search function which allows you to find a code for your zinwell converter box. Also, your Zinwell box instructions may advise you of what it is equivalent to (uses the same codes as)
Posted on Nov 10, 2012
gopakumarg43
  • 74844 Answers
SOURCE: digitrex remote control codes
0382,0829,0119,0963,0000 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Posted on Mar 15, 2013
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
Channel scan without original remote
You should have its remote control to do a channel scan. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops.
Check this link too. http://remotesearch.blogspot.com/
Apr 09, 2014 | Sharp Televison & Video
1. the newstar universal tv remote contrlol i bought, cannot change the channel, although i can use the adding/minus the volume. 2. in as much as wanted to use also for te change of channel, i follow...
Unfortunately, universal remotes often do not work as well as the packaging says.... but all hope is not lost.
First, try ALL the programming codes listed for your brand of TV. Often, one will work. Be sure to follow the programming instructions, which usually have you trying the POWER ON/OFF button first after reprogramming.
If that fails, most universal remotes have a "scan" feature that, when you start it, will cycle through every code it has stored. During a "scan" you keep the remote pointed at the set and when the set powers off, you hit the ENTER key (or the key specified in the remote manual) to stop the scan and test the functioning of your remote (channel +/-, VOL +/-, etc.)- it takes a long time and can get frustrating, but keep trying and you should find a set of codes that will operate your TV correctly.
If you have no luck, do not give up hope completely- I would next recommend that you purchase a Philips brand universal remote- this is the brand that I have found to be most flexible.
Mar 02, 2011 | Televison & Video
My universal remote went out and somehow the tv-a Sansui-got switched from channel 3. How can I get it back to channel 3 so the converter will work? I tried changing channels manually at the tv but it...
Look in the owner's manual for instructions on having the TV scan channels. Make sure the converter is on before starting the scan. If that doesn't work, you'll have to buy or borrow a universal remote to take care of it (enter 3, 03 or 003 on the remote control). This will happen every time you remove power to the set, whether it is unplugged or you have a power failure, so start saving up for a new remote control.
Dec 07, 2010 | Sansui 27" TV
What is the Remote Control Code for FLX1510
taken from their support f&q section word per word
"try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes. If there is another code listed for Element Electronics in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV’s model number for more information."
Oct 01, 2009 | Element Electronics FLX1510 15.4 in. LCD...
Digital converter box only gets 2 channels
You may need a different antenna. See www.dtvanswers.com for more info.
Jul 23, 2009 | RCA Universal Remote Control
I hooked my tv up to cable, but cannot get cable channels to work... you can get them by putting numbers in remote, but will not show up when you scan up/down button on remote. Don't haveoriginal remote,...
Is there a Menu button on the remote that activates the Menu function on the TV? If there is, launch the Menu and look for an option titled Channel Memory, or Channel Scan, Add to Memory, etc. This functon will scan the channels and add active channels to memory.
Jul 05, 2009 | Zenith Televison & Video
Televison & Video Logo
113 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
