Question about Electronics - Others
Is there a fuse in the unit and can it be accessed?
Is there a fuse for the radio?my radio cut off ,what should I do?
Here is the fuse block diagram. Check fuses #21 and #63. The fuse box is located under the rear seat which will have to be pulled up to access the fuse box
Nov 21, 2015 | 2000 Cadillac Seville SLS
More than one radio fuse??
Depending on the make model and year, you may have two power sources. One for radio memory, and one for radio operation.
The memory could be tied into the cig lighter or other circuit.
Nov 19, 2015 | Cars & Trucks
How to change fuse
If it is an over the range unit then the front control panel will come off and you can gain access to the fuse. A wall unit panel will open up and again gain access. If it is a counter top unit. the case will have to removed and you will gain access to the fuses. Now what tripped the fuse. It could be a bad door switch. a shorted high voltage capacitor or it may not be a fuse at all it could be the flame sensor tripped or the magnetron sensor. Some over the range units have a sensor that will shut it down if the stove gets too hot. look for burned connectors. be very careful of the high voltage circuit and make sure the power is off.
Oct 12, 2014 | Microwave Ovens
I have a GE JE1660 Profile Countertop microwave oven and it just quit. No warning, no lights, no response to any button pushed. Fix or replace?"
there is a 20 amp fuse inside the unit ,but requires to gain access.. may luck out and it just blew the fuse... normally they are behind the control panel unplug unit and take screws out to gain access hopefully that will fix you up ...if the fuse is good i would suspect you have a failed control board on the unit.... good luck
Feb 11, 2011 | Microwave Ovens
How to locate the fuse box in a '94 buick regal glove box?
The main fuse block is located in the underside of the instrument panel, in or behind the glove compartment. Remove the access cover in the glove compartment to access the fuse block. Spare fuses and a fuse puller should always be kept here. Various convenience connectors, which snap-lock into the fuse block, add to the serviceability of this unit.
On some vehicles, you may have to remove a cover for access to the main fuse block
The main fuse block is in or under the glove compartment
Dec 22, 2009 | 1994 Buick Regal Gran Sport
Does the unit have a fuse. I think i shorted it
Yes, I took this unit apart there are 3 40 amp fuses in the unit. (Similar to blade type car fuses). You have to completely unscrew everything plus take off the top lable and plate to access the other hidden screws
Oct 16, 2009 | Black & Decker Husky 750w Power Inverter
Location of fusebox on 1980 corvette
Fuses are located in the junction box below the instrument panel to the left of the steering column. The turn signal flasher and hazard warning flasher also plug into the fuse block. Each fuse receptacle is marked as to the circuit it protects and the correct amperage of the fuse. In line fuses are also used. Refer to the Fuse Chart at the end of the information for their location. The fuse block on some models is a swing-down unit located in the underside of the instrument panel adjacent to the steering column. Access to the fuse block on some models is gained through the glove box opening. The Convenience Center on some models is a swing-down unit located on the underside of the instrument panel. The swing-down feature provides central location and easy access to buzzers, relays and flasher units. All units are serviced by plug-in replacement. Location of Convenience Center on specific models may vary.
Oct 08, 2009 | 1980 Chevrolet Corvette
WHERE IS THE FLASHER FOR A 2003 HONDA ODYSSEY LOCATED?
the turn signal and hazard flasher unit is located on the backside of the driver's side fuse/relay box under the left end of the dash. to access, remove a nut on the left side of the fuse box and release two locking tabs from the upper and lower mounting brackets and remove the fuse box. Now you can access the backside of the box and change out the signal flasher unit. Its a black square plastic unit that pulls straight out.
Jul 19, 2009 | 2003 Honda Pilot
Have a honda odessey 2000. needs a new DRL relay; but cant find it under the dash _any ideas _
the daytime running lights control unit is behind the glove box. You must first remove the glove box to access the control unit. However, the fuses that supply power to control unit functions are accessible in several fuse boxes. the No. 3 and 8 fuses (15A) and No. 14 fuse (40A) in the engine compartment fuse box, the No. 5 fuse (7.5A) in the driver's kick panel fuse box, and the No. 6 fuse (10A) in the passenger's kick panel fuse box all supply power in some way to the DRL unit. Other inputs that can affect the DRL system include a faulty parking brake switch, faulty combination light switch, faulty headlight relays or blown bulbs, and even the brake fluid float switch.
Apr 04, 2009 | 1997 Honda Odyssey
Uniden VHF Marine DSC Series 25 Watt Radio
Typically there is an inline fuse in the power cord. It is not built into the back of the unit. If access to the back is restricted, they should have cut out the fuse and installed it near the power buss that the power cord is attached to. How was it flush mounted if you don't have access to the back of the unit? It's not possible to attach the flush mount brackets without access. It's possible that the radio is held in place using sealant. If you are sure there's no way to pull the panel, try gently prying the radio out of the hole working around the edge to break the seal.
May 08, 2008 | Uniden Oceanus DSC Wham ready Fixed Mount...
Electronics - Others Logo
186 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
