Question about Electronics - Others
Is there a fuse inside? And can it be replaced?
Red light is on in the back of my t300 tower speakers
That is the standby mode but if its not kicking out of standby mode it could be a fuse issue
The T300 uses a 2.5A fuse.
To replace the fuse:
1. Unplug the AC cord from the AC power source,
then remove the AC power cord from the speaker's
power connector.
2. Remove the fuse cap with a small, flat blade screwdriver
(see diagram 2).
3. Remove the fuse from the fuse cap
(see diagram 3).
4. Replace the fuse inside fuse cap with another metric
5X20mm size fuse
5. Replace the fuse inside the cap, replace the fuse
and cap in the power connector (see diagram 5).
6. Connect the AC power cord to the speaker and
raise it upright.
7. Connect the power cord to an AC power outlet
Jun 01, 2011 | Cambridge Soundworks ton Theater T300 Home...
Power window's locks and mirrors do not work. Is there a fuse that could be replaced or a bad relay?
Yes there is a fuse that can be replaced. Find your fuse box(there may be two) in the vehicle or in the engine compartment. And look at the cover of the box, there should be a listing of what fuse belongs to what systems. Check the appropriate fuse, if blown in the middle, replace with same amp fuse.
Feb 06, 2011 | 2004 Jeep Grand Cherokee
Can not fine fuse
The fuse of Nissan cars are in a box, and it is located under the dashboard of the passenger side of the front seat in Your car. If You intend to replace a blown fuse or check the fuse, please follow the steps below:
  1. Start by turning off the car. Locate the main fuse box under the dashboard of the passenger compartment of your Nissan.
  2. Pull the cover down to open and towards you to remove it. Read the inside panel of the fuse box to figure out the location of the fuse you must replace.
  3. Use the fuse puller inside to remove the appropriate fuse. Look at the wire in the middle of the fuse to see if it's burnt.
  4. Replace the blown fuse with a new one of the same rating. Verify the fuse's rating against the inside cover of the fuse box. For example, the 2006 Nissan Sentra has a 10 amp mini fuse.
  5. Push the fuse in and close the cover. Check the fuse once the car is started.
Hope this helped. Thank You for using FixYa!!!
Jan 27, 2011 | Nissan Maxima Cars & Trucks
Cigarette outlet doesn't work. I'm not sure which fuse to replace and I don't have an owners manual. Please help!
inside your car there is the fuse box and on the inside of the cover should be a diagram and the fuse labeled accessory is the fuse that will need replaced if it isnt blown then yor lighter needs replacing
Jan 13, 2011 | 1995 Pontiac Grand Am
Hello...I am an owner of the Fender Passport PD-500 Sound System
Replace the fuse only once. If it blows right away, then servicing is required as continued replacement will likely damage more inside.
Most of thes have a fuse holder that is a part of the input power socket. There is a little rectangular panel adjacent where the cord connects with a tab that you gently pry out and carries a small fuse. Replace the fuse and re-install the carrier.
These units are very hard to work on due to packaging.
May 30, 2010 | Fender Passport Deluxe 500watt Sound...
Describe how I access the inside fuse board?
I checked my Camry's manual which described how to open the cover over the board. The diagram on the inside of the fuse board cover identified the location of the cigarette lighter fuse. I replaced it with the spare 15amp fuse found in the other fuse box next to the engine block, also described in the manual. However, this did not correct the problem. On a hunch, I pulled the fuse labeled "power point" and saw the burnt filament in the fuse and replaced it with the 15amp fuse. This corrected the problem.
Jan 26, 2010 | 2004 Toyota Camry
The turn signals do not work. could it be a fuse?? The inside lights do not work when you open the doors. where is the master fuse box located at???
The fuse box is always under the dash on the driver's side. Replace the fuse that is blown. You will find an extra fuse inside the fuse box. use it, but replace it with the correct value fuse when you can.
Jan 04, 2010 | 1998 Ford Taurus
My windshield wipers fluid motor stoppped working,is there a fuse I need to replace.I have a 2007 ford edge
Hi the chances are its not a fuse thats gone its more likely going to be that the motor has seized this happens if it hasnt been used for a while.
If you look inside the fuse box you should see printed on the inside lid the location of all the fuses and if its not written on the inside of the fuse box then the chances are it is going to be written inside the owners hand book, so look in their and then check the fuse for that part.
If you cant find any fuse location instructions then just look inside the fuse box and replace any fuses that are blown if you find any then if it is a fuse you will find a blown one and then should solve your problem.
So if you find no blown fuse then the chances are its going to be the motor this would need testing to see if you hed power going to it if their is no power going to the motor then this would indicate the switch itself was faulty and would need replacing.
Let me know how you get on or if you need further assistance ok
Jan 03, 2010 | 2007 Ford Edge SEL Plus
I think maybe the fuse blew
Just open the unit,find the transformer,the fuse is there only,near the transformer, if you find the fuse check the continuity if not be open,if busted replaced it with identical amperage...
hope this may help;
Regards,
votit
Aug 09, 2008 | Sony STR-DE197 Receiver
Electronics - Others Logo
168 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
