Question about Cannon Office Equipment & Supplies
What is error code E000003-0002 on cannon irc 3380i
I have bought this second hand photocopier all in one, one I turned on, it initially shown error code E000990-0000. However after the second attempt, it shown the error codes E000003-0002. When I opened the right door of the photocopier as was instructed, it appeared to me bit tilt on left side and so not closing the Right lower door perfectly. Pls help me to fix this fault. Thanks- MA
  • Cannon Master
  • 521 Answers
Hi . The second error indicates there is a temperature problem in the fixing unit. You need to clear that error from service mode first.
with the machine turned on Press the next:
Press aditional function once
Press 2 and 8 at the same time once
Press aditional function once again .
Service mode should appear in the screen . If doesn't repeat the secuence until it does .
Then in the touch screen
select copier
Select Function Select Clear
Select ERR and press ok in the lower corner of the touch screen .
Turn off the machine for a few seconds (5)
Turn the machine on . If problem persist that mean the fixing unit is defective
Posted on May 16, 2017
  • 389 Answers
SOURCE: I have a Xerox docuclor
include device, open lid, press [MENU], [6], [4], [CLEAR], [ENTER]
Posted on Oct 03, 2009
  • 1219 Answers
SOURCE: Canon iRC 3380i error code
Service Bulletin
Issued by Canon Europa N.V. Copier Color
Addition of the Affected Machines
Hopper Assembly
Measures against E025 error due to toner leak
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Ref No.:
iRC3380-023 Rev. 2
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
New FC6-9380-010 GUIDE, UNIT CABLE,
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Posted on Jun 15, 2010
  • 241 Answers
SOURCE: I have a xerox Docucolor 12 with a fault code
check sensor (side of paper out)
Posted on Oct 05, 2010
  • 30 Answers
SOURCE: When printing, only half of
You may need to run a clean cycle to see if it will clean the printing drum. Also try removing the toner cartridge and shaking it gently.
Posted on Mar 07, 2011
F Victor man
  • 824 Answers
SOURCE: I have a cannon MP 510. When I turn it on, the
I suspect you had a paper jam and removed it from under the main cover. It sounds like you have got grease on the encoder strip (the long blackish plastic strip that runs the full width of the machine. The carriage looks at the encoder so it knows where it is. Clean the encoder with soapy water on a cotton bud. You may have even snapped the encoder which will mean you will need a new one.
Good luck
Posted on May 26, 2011
How can i fix the error code e000002 shown on my canon ir 2520 photocopier
Unplug the printer let it sit for one minute than power it back up. If the error doesn't clear repost.
Mar 05, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
Init 2 error 0004
You might want to post this question in a different section. This is the computer section.
Jul 07, 2012 | Computers & Internet
I bought my Harrier 2.4 yr2001 two months ago for a used car dealer. During the few initial test drives my friend and I did not suspect anything wrong with the engine and everthing seems just fine. After...
The initial thing that i see is your vehicle is too young to show that type os code.the two digit code 23 has not been used since 1995.It's an obd1 code.Your vehicle has obd2 class diagnostics on board.The code would be po171 or po172 for example. I would get a second opinion if i were you .Try running a few tanks of premium fuel. This can often wake up an o2 sensor by cleaning it up a bit.Hope this information helps,
Oct 08, 2010 | 2001 Lexus RX 300
Ricoh FT 4015 too dark
Depends how many copies are in it. The PCU goes at about 60,000 prints its ordered as a supply. This is the heart of the machine. Lastly would be the fuser. -Carl
Jul 10, 2009 | Ricoh Office Equipment & Supplies
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
I too have just bought a 2nd hand printer (Tally T8006) that also worked well until the fuser oil seemingly has to 'swamped' everywhere and which now throws up the same error code as above. Will attempt to 'dry it out' and see if the code clears. Have also recently sourced an original installation CD, will check out fault codes when it arrives - Gazz
Aug 31, 2007 | Tally T8006e Laser Printer
Will not initialize
Take it back to the dealer! Better do not fix that problem by opening the printer! If it is a second hand printer, write again here.
Aug 26, 2007 | Brother MFC 420CN All-In-One InkJet...
184 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
