Question about Kettler Exercise & Fitness
Hi an oil can symbol has appeared on the display of our Kettler Traveler treadmill. I have lubricated the belt but the symbol is still there. Any ideas what it could be please? It keeps stopping too.
    Top Expert:
  • 50,211 Answers
Contact the manufacturer thru their website and tech support
Posted on Apr 21, 2015
I have Kettle pacer treadmill,when I press start button the display shows error DC 6 and belt does not move
have you kept the belt regularly lubricated ?
can't find this error code in manual
Nov 25, 2014 | Kettler treadmill Pacer
How can i oiling my kettler pacer belt ?
you dont oil it, you have to put treadmill wax on it, and you just put it under the belt on top of the deck at the front and the back
Apr 25, 2014 | Kettler treadmill Pacer
Treadmill displaying temperature over for an mbh fitness.what are the possible causes?
The cause of this problem is because your powerboad need big power (Amp) to turn the motor (and the belt) This usually happens if your treadmill belt is not lubricate well or needs change. So, first try to lubricate your treadmill belt with silicone oil and be sure that treadmill deck is clean. If the problem continues you must change your treadmill belt.
Greetings from Greece
Oct 18, 2013 | Horizon Fitness Exercise & Fitness
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 28, 2012 | Kettler treadmill Pacer
Kettler alpha xl treadmill
Kettler alpha xl laufband typ 7894-600 err3
/uploads/images/kettler-alpha-xl-treadmill-34874487-1-1.jpg
Aug 01, 2012 | Exercise & Fitness
LUBRICATING OIL FOR TREADMILL MOTOR BELT
Hi, I used to work in a commercial gym and part of the weekly maintenance was to lubricate the belt. Oil will be available from your machine's manufacturer. If it's a home use treadmill frequency will be much less and your manual / manufacturer will be able to advise at what interval, usually in hours. Hope this helps.
Mar 23, 2012 | Exercise & Fitness
MY TREADMILL STOPS JUST A MINUTE AFTER STARTING.
Try Lubricating the belt with silicone spray.
Probably the resistence from the belt scraping over the ground board is too high, forcing the machine to switch off in order to prevent damage.
Jul 24, 2009 | Kettler Exercise & Fitness
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Kettler treadmill "silikon wartung"
Hi eirik,
Your treadmill needs lubricating.
Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
That should do the trick.
Mar 29, 2009 | Kettler Exercise & Fitness
I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Dec 02, 2008 | Exercise & Fitness
Exercise & Fitness Logo
155 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven Brandon
Steven Brandon
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
