Just changed bulb in tv. I can here the fan but tv won't come on and power light blinks twice with yellow light. What's wrong?
  • 104 Answers
Your ballast has gone bad, you can buy the part on ebay for around $70 I know this from experience as I repair tvs for a living, you would have to pull the whole assembly out where the bulb is and replace the board that has the wires that go to the bulb
Posted on Apr 22, 2015
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
SOURCE: Blinking Yellow light on a HD 65" DLP Toshiba TV
I have a 56 inch tohiba DLP (56 HM 195). Replaced the bulb for the second time this year. last time only lasted 3 months. TV is tough to turn on. When I get it to turn on, and then shut it down, the yellow light blinks constantly for 5-7 mintues. Then it shuts down completely. Is the set overheating? There is nothing in the manual that speaks to this issue. thank you
Posted on Aug 15, 2009
  • 5 Answers
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Posted on Sep 09, 2009
SOURCE: Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
Posted on Oct 15, 2009
SOURCE: Red Light Flashes twice KDF-E50A10
I just went through the same problem. I replaced the bulb myself and when i put it back together it turns on then goes out. I had 3 red lights. i checked the trap door and the lamp assembly many times and it wasn't that. I finally took it to a repair place and they told me it was a power supply issue. $200.00 total to fix. Works fine now.
Hope this helps a little...
Posted on Nov 23, 2009
How do i determine if my ballast board or capacitor is bad in my toshiba hd tv model no 57HM167?
The chances of the ballast failing are small on this model. Count how many times the Yellow light flashes before it pauses. Then google 57HM167 and the amount of blinks. ie " 57HM167 Yellow light flashes 3 times" That will tell you what you need to know. You can also post it here and we can help. I suspect you have a stuck fan(the fans are monitored to see if they are spinning. If not, they will not allow the TV to start up). Or you have the cover for the lamp not installed all the way. There is a switch that the lamp cover activates and the the TV will not turn on without it secured.
Apr 02, 2015 | Toshiba Televison & Video
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Tv dont power on green light flash then turns off red lights blinks 5 times
Had that problem and replace the lamp twice, I finally replaced the optic block.
It is quite involved to replace, if not technical get professional help.
Mar 21, 2014 | Sony KDS-60A2020 60" HDTV
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
Tries to power up twice, then 3 blinking lights on tv. bought an aftermarket bulb and still does the same thing
hi if the bulb did not work then there is something else wrong with your tv. Something else is not turning on the bulb my first guess would be your backlight inverter.
You can get get parts for this tv at www.interliquidparts.com
Nov 23, 2011 | Samsung HL-S6187W 61 in. HDTV
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Apr 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
