How would I connect the Kross Bazooka USB computer speakers ?
2 Suggested Answers
  • 46 Answers
SOURCE: Good Morning. I've purchased
If you have Win XP SP2 or higher you should be fine with just the USB speakers. When you plug them in the computer will tell you if it found the speakers and installed the driver for them. It will say equipment is installed and working or it will say equipment did not install properly if there is a problem.
Posted on Mar 08, 2011
Kross speaker remote no longer works. is there a way to fix it? if not will a universal remote be good for replacing it?
The remote may need fresh batteries. A universal remote may not be able to generate the codes required to control the speakers.
Jan 01, 2014 | Audio Players & Recorders
Audiopipe amp 1000w on 2 8" double ended bazooka
You may be over driving the speakers or there may be an impedance mismatch between the amplifier and speakers, especially if they are connected in parallel
Nov 12, 2012 | Car Audio & Video
New KROSS DVD player has problems with USB drive
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jan 10, 2012 | Computers & Internet
Good Morning. I've purchased kross bazooka thunder usb stereo speaker do I need to install a special driver or sound card and do you know what will work with windows xp. Thanks for your time.
Mar 08, 2011 | Audio Players & Recorders
Hello the bazooka power wont come on
So it is a powered tube, yes? Can't remember, does the Bazooka have a fuse on it? If it is powered, you blew the board.
Apr 07, 2010 | Bazooka BTA8200 Car Subwoofer
The wires that are connecting the speaker to + & -
Soder the connection on there. The wires used are just basic speaker wire.
Oct 09, 2009 | Bazooka CSW1004 Car Speaker
Pioneer GM5300T-760amp w/bridgeable
It sounded like you checked, but I had to ask.
Lets see if the Bazooka is the problem:
If you have two other speakers around somewhere, you could try hooking them up (one to a channel, un-bridged). Start with the gain at it's lowest and slowly increase it.
If they work, good news. If not, we've isolated the problem to the Amp.
Your Bazooka: Is it a double or single speaker?
Some tubular models don't allow easy access to the back of the speaker to find out the impedance rating.
Speakers rated at 4 Ohms or less wired parallel on bridged connection will trigger the Amps self protection mode.
This test should tell you if it's too low.
Try your bazooka on a single channel (instead of the bridge).
Try these and get back to me.
Good luck
Mike
Jul 20, 2008 | Car Audio & Video
What up with my subwoofer?
Sometimes the Bazooka tubes have an internal amp. I am not sure of this model but maybe you can Splice in directly to the Speaker Wire and bypass the AMP in the Tube if it has one
Feb 06, 2007 | Bazooka BT6014 Car Subwoofer
 Grubhead
Grubhead
