Jabra Cruiser 2 Bluetooth In-Car Speakerphone for Cricket Kyocera Luno S2100 Logo
T
Tom Wren Posted on Apr 21, 2015
I need instructions for paring with my phone - Jabra Cruiser 2 Bluetooth In-Car Speakerphone for Cricket Kyocera Luno S2100
Dave Sattler
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 26, 2015
Dave Sattler
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
535
Points
7
Make sure your phone is on discoverable bluetooth on, power on your device, it will be auto on, then your phone may give you a code to punch in or you may just connect. Pretty simple, I found it sometimes asks you to put the code in if you are some distance from your device, ignore it, it should just take a minute and will connect auto.
I need paring instructions for my HS850 to my Iphone.Both from the HS850 and the Iphone side.
To pair the bluetooth headset with your iPhone. Switch on the headset. Then in the iPhone goto settings then bluetooth you can see the iPhone is searching for devices. If it sees your HS850, just click on it and when asked to enter a pin, give in 0000.
Once the iPhone knows your device, I should find it every time both are switched on. (Bluetooth must be switched on on the iPhone)
2helpful
Isound road talk transmitter paring pin code?
Just purchased, couldnt find documentation in the package, tryed toguess the code per usual standard device pin codes. 1234, 0000, to no avail... but I looked a little harder for the documentation in the package, subsequently found the instructions behind a false panel, and the code for pairing is 9999... there you go. Good luck everybody!
4helpful
Not in english? I bought the ProMedia Stereo Bluetooth Headset product in the Netherlands, and need the manual in English.
I can translate the whole instructions but most functions speak for themself.
The only problem I think you are facing is how to connect to a mobile phone, computer or tablet.
This is colled paring (pairen in Dutch) see page 7.
A short translation of this page in English.
Turn the headset on. (page 3, pt 4)
For pairing hold the multifunctional switch (page 3, pt 1) for about 10 seconds. the light (page 3, pt 2) will blink from red to blue and repeats this in a continues mode. Now the headset is in paring mode. You can now find it in your mobile phone list.
If your phone is asking for a code then type four times a 0.
If you are out of reach the headset will connect again on it's own only when in reach within 2 minutes.
After switching off then on the headset will try to pair with the latest paired phone/ computer.
I am using the same headset with upgraded speakers. Works fine with a Ipod Toch and mobile phone.
Good luck.
Hi got a ford focus zetec having truble paring the phone with car any
Check the number of phones already paired with it. Follow the instructions exactly in the manual as it gives you a code to enter
3answers
How do I connect my IPOD nano to my Motorola S9 HD Headsets
I downloaded the instructions manual for the Motorola S9 HD and implemented them. It worked fine!
2answers
Paring the Bluetooth
You have to enter the security code into your phone once the phone receives the connect to signal from the radio, the default code is 1111
1helpful
Lost instruction book
go on ur phone and go 2 bluetooth pairing. before u click pair, turn on ur headphones and hold the multi function( button w/ play button and phone symbols) button until flashes blue and red lights simultaneously. once flashing, enter and start bluetooth paring on ur phone. the code is 0000. enjoy using ur bluetooth.
Paring
you simply pair two phones together. did it work? let me know.
Top Jabra Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Jabra Audio Player and Recorder Expert? Answer questions, earn points and help others
