Question about Vacuums
I have a bussell proheat 2x and the spinner doesnt want to spin
    Master:
  • Vacuums Master
  • 755 Answers
Hey this is Jim with Crucial Vacuum,
First be sure to double check that your Proheat is in the right setting. In this case you want the Floors setting instead of the tools setting.
Also, check to see if there is a clog around your spinner. If so remove any noticeable debris. This is usually in the form of hair, or carpet fibers. This should improve your suction and get the spinners moving again once any clogs are removed.
I hope these tips can be of help. If you're looking for replacement parts to your Bissell Proheat you can purchase them directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=pro+heat
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Apr 22, 2015
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: bissell proheat 2x
Check the brush motor, I have had to replace of few of them. If the brushes aren't turning, this could be the problem.
Posted on Apr 18, 2008
heatman101
  • 43501 Answers
SOURCE: 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum: I have a Bissell proheat 2x deepcleaner 9200 model...
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fkj
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: my carpet cleaner doesnt **** up the water
heatman101
ydtyd
heatman101
  • 43501 Answers
SOURCE: Bissell PROheat 2X No longer sprays water
heatman101
Posted on Oct 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
The water in my bissel pro 2X heat will not spray water
front tank is warped and not seating properly or solenoid bad. solenoid most probable.
May 05, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The unit does not put any watter on the carpet and when I push the triger the red spinner does not move. The tank is full of hot watter
This sounds like your pump brush belt is broken in your Bissell. The belt controls the pump in the machine, as well as the brushes. This would be explain why the solution is not spraying, as well as why the red spinner on the top of the machine is also not spinning.
Here's an extremely helpful video that you can watch on how to replace the belt on your Bissell ProHeat Carpet Cleaner.
If you open up the door and find that your belt is not broken, please just reply using the Clarification Request form here on the Fixya website, and I'll be more then happy to do some advanced diagnosing with you to figure out what the problem is.
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt:
http://www.bissell.com/VideoRating.aspx?id=1555
If this information was helpful to you, help other Fixya users with the same problem find this video by clicking the very helpful four thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris J.
GoVacuum.com
Apr 12, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Turbobrush not spinning for bissell proheat 2
heatman101
tyee3
Sep 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The water does not shoot out of my bissell proheat shampooer. The red spinner has stopped spinning.
I'm not sure I have the same kind of machine as you because I don't think I have a red spinner. However, I did have the problem of water not shooting out (although the solution was being used up, just not the water). The problem turned out to be the plug underneath the main tank. To find out if this is your problem, lift out the main tank and take it to the sink. Feel underneath for the plug. Push inside of it. Water should squirt out (assuming there is water in your tank). If it doesn't, turn the tank over, unscrew the plug, and push the thing inside until you get it to spring up and down. If it won't do that, you might need a new one. If it springs, screw it back and try your machine again. Mine worked good as new after I did this. Good luck!
Dec 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Re - Assemble
heres the manual for your vacuum this should help you out. let me know if it doesnt
CLICK HERE
Jun 15, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x
Apr 18, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
