Tub and agitator turn at the same time n the same direction
    Top Expert:
  • Washing Mach... Master
  • 51,127 Answers
Better call a repairman you got a bearing problem
Posted on Apr 21, 2015
  • 473 Answers
This is usually caused by a bad transmission. Depending on washer age this will be expensive. Some machines have a 5 year PART ONLY warranty on the transmission so you pay for home call and labor. If over 5 years it probably isn't worth it . Check your owners book for any extended part warranty.
Posted on Apr 22, 2015
The agitator is only working in one direction so the washing is getting tangled
The top portion of the wash tub agitator is designed to rotate in the clockwise direction. It should be intermittent. Turn stop turn stop ....in its normal operation.
There is a set of plastic cams that allow for this function. Below the top agitator the lower agitator goes back and forth. With a short load the water just reaches the upper agitator. Try short load. Other possibility the tub is under filled try increasing the water level.
26221857-hkbf5riehselkv40qtw2in2z-5-2.jpg Two piece agitator
26221857-hkbf5riehselkv40qtw2in2z-5-5.jpg Two piece agitator.
Hope this helps?
Jun 20, 2016 | Washing Machines
Agitator only turns in one direction
Check the motor/transmission drive coupler for wear
Feb 20, 2014 | Washing Machines
Machine is working but clothes are not getting clean
Check the agitator. you should be able to, by hand, easily turn it in one direction without turning the tub while the other direction turns the tub also. If the tub does not turn in one direction with the agitator the you need a new clutch dog assembly or the whole agitator. Hope this helps. Good Luck
Mar 12, 2011 | Estate Washing Machines
Maytag Performa washer drum turns with agitator. Also the brake doesn't stop the drum at end of cycle or when cover lifted.
The first thing to check is the clutch. It's supposed to lock the inner tub and drive the transmission (agitator) when the motor turns in one direction, and spin the tub when the motor turns in the other direction. It's also possible the agitator drive shaft coming out of the transmission and the concentric tub drive shaft are frozen together (worst case) - this is usually caused by a bad bearing seal allowing water to leak into the shaft.
Lifting the lid during the spin cycle should disconnect power to the motor - maybe what you see is the tub continuing to spin because the transmission is acting as a flywheel. Either that, or the lid switch actuator is not working properly.
Nov 27, 2010 | Washing Machines
Tub won't spin
Your direct drive coupling is broken. Follow the instruction in this video for repair.
Apr 21, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Washer, LAT2300AAE, won't spin
ok lets see here;your transmission can go in two directions.if you turn the middle pully one way it will agaitate if you turn the oppisit direction you can watch [from under neath]the brake raise as the cam seperates and lifts the brake.now with the brake lifted ,your tub should spin.if its not lifting the brake you need a new center pully kit[i have had to do many]it comes with washers ,bearings and cams.if the brake lifts and your tub still wont spin you may have a pice of clothing between the two tubs[i had that one to,many times]i hope that helps.you can email thru fixya if need more advice God bless ,tom
Jan 26, 2009 | Maytag Dependable Care LAT9706
Tub won't agitate
locked up pump? object in pump?
Jan 13, 2009 | Washing Machines
Washer won't agitate or spin
The transmission is dead!
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
1998????????????
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Aug 01, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer does not agitage the clothing. The clothing rotates in one direction within the washer tub.
Hold the inner tub and turn it bothways. if it is free in both directions you have a bad bearing. If it turns in one direction only, the bearing is good.
Your agitator has a series of interlocking teeth on the inside which lock onto the corresponding teeth of the motor shaft. If these plastic agitator teeth are worn it wont grip the drive shaft, hence, no agitation.
Jul 23, 2008 | Maytag Washing Machines
Washing Machines Logo
Top Washing Machines Experts
