Question about Philips Televison & Video
How do i program my remote philips rc 8102/01 to my tv and receiver?
  • nejib barhoumi
    nejib barhoumi Apr 25, 2015
    Ihave a philips remote controle without users guides and i can't need it to controle my tv thomson and sat dy telecom.
Sparky-UK
  • 129 Answers
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 30, 2007
kitquint
  • 40 Answers
SOURCE: Remote programing for TV after changing batteries
HOW TO PROGRAM GE Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
Posted on Sep 15, 2008
SOURCE: olevia rc ltu remote
http://remotes.com/remotes/documents/Olevia/532.pdf
Posted on Dec 22, 2008
gcrcomputers
  • 170 Answers
SOURCE: I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
Posted on Mar 17, 2009
  • 5 Answers
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Posted on Jul 17, 2009
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
I have an Onkyo DR-S2.0 dvd Receiver that will not turn on. That aside I'm trying to find codes for the remote in order for it to learn my Philips tv and my Yamaha stereo receiver. The remote is a RC-437M....
Can't help you with the turning on problem, but the remote doesnt use codes to control other devices it learns the signals from that devices remote. heres a link to the users manual:
http://www.intl.onkyo.com/downloads/manuals/pdf/dr-s2.0_manual_e.pdf
the programing procedure is on page 63
May 21, 2010 | Onkyo RC-549M LCD Remote Control
Philips TV 42pfl9664 remote control interferes Onkyo
HI it is entirely possible that the function you are using on your tv has the same command that your Onkyo uses for selection of GAME-mode. You should be able to prove this by using the Game-mode button on your Onkyo remote and it should affect your TV.
If Not then try shielding the remote receiver on your stereo with something thick ( a piece of paper is transparemt to IR - use a book or pillow) and see if the problem clears.
If this test proves correct, then the only solution is to see if you can change the remote command ID on the stereo and remote (if it supports it). The philips will most probably not have this feature. otherwise the only solution is to upgrade 1 device for a different brand.
Mar 21, 2010 | Philips Televison & Video
Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Aug 17, 2009 | Directv RC-64 Remote Control
Hughes remote codes
The only model of remote that i heard that it has pre-program Olevia code in it.. is the RC-64 or RC-64RB usually these remotes are coming with the new HD boxes..
Direct TV
Remote Codes 506 or 127
Direct TV (Remote Model RC-64RB)
Remote Codes 11144, 11240, 11331, or 11610
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available… please call at 866-965-3842
Jun 02, 2009 | Syntax Olevia 226T 26 in. LCD Television
I am trying to program a new remote and i need my remote code to program the tv can you find the code for magnavox msd513f
Not sure your MSD513F is not listed, and dont know your chassis # so here is what I can offer with what you gave me from the manuals
FOR THE
51MP392H/17
PHILIPS phone # 1-800-432-8542
Universal remote control - RC2018/1
Universal RC managing TV and peripherals
from the parts manual
Cabinet & Accessory Parts
REMOTE Transmitter, RC2061/01 . . . . . . . 3128 147 14611
Sep 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
CANT GET TOSHIBA CT 90302 TO PROGRAM
I had the same problem, and the solution above/below that says to use code 018 worked for me. Yeah!!!
Sep 01, 2008 | Kenwood RC-R0720 Remote Control
Televison & Video Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
