Question about LG 50PM6700 50 Inch 3D 1080p 600Hz Smart TV Plasma HDTV Bundle
Where can I find instructions on how to install the legs
  • LG Master
  • 5,472 Answers
The User's Guide for the LG 50PM6700 has the directions for attaching the stand and is available on the product support page: http://www.lg.com/us/support-product/lg-50PM6700# . The directions start on page 17. Scroll down to the downloads section, the second link gives the manual in a PDF format. The first link has the manual as a DjVu file.
I hope this helps.
Posted on Apr 21, 2015
I have a leg of lamb 1.225k what temp and how long do I cook it for please
Hello, Brenda -
If you want to roast a leg of lamb, in the oven, you will find instructions here:
https://www.allrecipes.com/recipe/9380/roast-leg-of-lamb/
This is a link to another recipe for roasting a leg of lamb:
https://www.thekitchn.com/how-to-roast-a-leg-of-lamb-cooking-lessons-from-the-kitchn-202391
Your question was posted in the Fixya.com category for Grilling, so in case you want to cook the lamb on a grill, see the instructions here:
https://www.epicurious.com/recipes/food/views/grilled-marinated-leg-of-lamb-234655
If you wish to find other leg of lamb recipes, use your favorite search engine (Google, Bing, Yahoo Search, etc.) and enter one of the following search phrases, using quotation marks as shown:
"leg of lamb" roasting
or
"leg of lamb" cooking
or
"leg of lamb" grilled
Best wishes.
Apr 01, 2018 | Grilling
I just bought irect water heater model HL40Sk ,is heater comes with legs it was nothing in corton ?
It most likely is a wall mounted model. Did it come with instructions? That will show you how to install it.
Sep 09, 2014 | Dunkirk HL40SK Hotline Indirect Domestic...
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
The dishwasher is moving around. i need to replace the wood under the legs. How do i adjust the legs. Plus what type of fasteners should i use into the counter
It would help if you provide the actual model number of your Miele dishwasher.
Typical installation instructions are shown in this site.
I don't think you would be putting wood under the legs. Most likely it will be a pair of tracks that are listed in the installation instructions. You could try to get these from the Miele service centre in your area.
Hope this helps unless you can let me have the actual model no. of your dishwasher.
Oct 09, 2010 | Miele Dishwashers
EXCESSIVE VIBRATION
Sounds like it needs to be leveled. Follow the instructions for setting the legs and make sure the plastic feet are installed on the legs. If they are not there call the retailer and have them get a set for you.
Apr 20, 2010 | Admiral AW22 Top Load Washer
Bought a corner bath a week ago and it has not got any instructions with it on how to fit the legs on
most corner baths have to be fitted securly to the floor and to the wall under top edge some legs are stuck on by double sided pads also some installers block up under seat areahope this helps
Sep 27, 2009 | Home
I dont have the instructions to turn my simplicity 4 in 1 crib to a toddler bed
Install Safety Rails
Mattress support must be in lowest postition
Remove the Front Panel Contoured Top rail and Front Panel
Loosen connector pieces on the end of the leg of the Safety Rail to the End Leg using two of the Allen Bolts (11/2 in). Loosely attach the leg of the Safety Rail to the underside of the Mattress Support using one of the short Allen Bolts (3/4 in) through connectors. Tighten all three of the bolts holding the safety rail to the unit.
Repeat procedure with the other safety rail.
These are the instructions in the manual. Basically, you take off the front cross board and rail, attach the safety rails to each of the front legs. They kind of go 1/3 of the way across the front with about a 1 1/2 foot opening in the center.
Apr 08, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
LG 50PM6700 50 Inch 3D 1080p 600Hz Smart TV Plasma HDTV Bundle Logo
