Question about Garden
How to repair the drivebelt on 30" riding mower murry/HP
  • 246 Answers
SOURCE: Is this for only Craftsman
Hello:
From your Description it Sounds like the Shifter Rod has Broken Inside the Transaxle or the Shift Keys have the Shifter Lever Locked in the Neutral Position and the Keys Require Replacing.
>>On the Transaxle is an OEM Identification Plate. Send me the Information Off of This Plate, Please. With this Information, I can Locate the Proper Manuals and Better Assist You.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 252 Answers
SOURCE: i have a murry riding mower. The drive belt needed
here is website for murray
http://www.partstree.com/parts/?lc=murray&mh=8
select your model from the list
( get your model number from off the mower it will be on a sticker somewhere on it possibly under the seat )
find the section you need it will give you the belt routeing
be sure to get correct model from list
cheers paul
Posted on Aug 13, 2010
SOURCE: I have a murry riding mower model #42515x92a
I have the same mower my belt is running on it. I can draw it for you. dannyehartley@gmail.com
Posted on May 07, 2011
  • 640 Answers
SOURCE: how do i kill engine (shut down, turn off)
If all the safety switches and the key switch do not work to stop the mower , there are only a couple of things you can do. One thing you can do is to use a stick like a broom handle by inserting it between the engine and the spark plug wire and popping the wire off, that will shut it down immediately. I have never tried to grab the spark plug wire of a running engine to see if the insulation will protect from shock, this is because high voltages generate there own induced voltages, I do not know if it is high enough for that. It will not really hurt I think, just a little buzz. Anyway, onward. There is another way, interrupt the full to the carburetor. If the engine has a couple of wires connecting to the bottom of the carburetor, that is the backfire preventor and if it is deenergized it will close a valve in the carburetor and kill the engine by starving it of fuel. If no such thing exists on your mower, you can use a small pair of vise grips and clamp onto the fuel line and the engine will starve for fuel within a minute or so if it is done properly.
After the engine is stopped, get the ignition switch fixed!!!!!
I hope this helps you out.
Posted on Aug 28, 2011
  • 5522 Answers
SOURCE: I have a 46" Yard Man riding mower with 20 hp BS.
Hello, Ask your local Mower shop if they show a Thermal switch for the PTO. You may have to replace it or move it away from the heat.
Posted on Oct 07, 2011
What is the belt length of a riding lawn mower MURRY 12.5 hp/40
If you have not destroyed the old belt take it with you where you are buying the new one and have them match it up . They will match as to the size and length of belt. They can do this even if its broken. They also take into consideration the stretch.
Mar 15, 2015 | Garden
I am seeking a service manual for a Murray ride on mower Model 405600X50B
Find a customer service number for Murry. Most likely they will
need model and Serial number. Probably will send you a replacement if your "nice about it".
Feb 27, 2015 | Murray Garden
What is the fluid type in a murry auto drive transmission
I use 30w motor oil, plug ( either rubber or steel ) is on top.
Jul 07, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Need model number and year of my murray ultra 19 hp 46 in cut mower.
OL BOY , MURRY PUT THE ID TAG ONE THE REAR OF THE MOWER SOME UNDER THE SEAT AND PLACES LIKE THAT THE ONLY PROBLEM IS IT'S A STICKER NOT A PLATE. COULD HAVE FADED OR NOT READABLE CHECK AROUND YOU SHOULD FIND IT
Aug 21, 2009 | Garden
Want turn over murry riding mower 12.5 hp just makes a click sound evertime you turn the switch on.
If you have a good battery, then most likely the starter solenoid needs replacing
Jun 13, 2009 | Briggs & Stratton Garden
The motion belt keeps coming off the pulleys this ( Murry )
I think you need a new belt. maybe it's stretched to much now this will make it slip of. also clean the pulleys maybe oily or something.
Jun 10, 2009 | Garden
Murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
Jan 17, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
