Question about Ovens
Oven fails to re-ignite after set temp is reached
  • Ovens Master
  • 5,323 Answers
Check the oven temperature sensor
Posted on Apr 22, 2015
  • Jorge Rendon
    Jorge Rendon Apr 22, 2015
    and the oven gas safety valve
    check the oven temperature sensor
Frigidaire Oven Problem
please post the model Number here..so i can look it up but just off hand there maybe an oven sensor (thermistor) problem this in inside the oven and tells the electronic ctrl board what the actual temp is in the oven it says 135 beacause it will until the temp reachs that after that as the temp goes up it will read 140 150 160 .. and so on until it reachs the set temp .. Is the oven getting hot and are there any fault codes coming up??
Jan 28, 2008 | Ovens
GE profile Spectra gas range/oven is taking approx.20-30 min to preheat. Once it finally reaches temp. it seems to hold at that temp and maintain it. I have noticed occasional puffing sounds when it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 17, 2011 | Ovens
Whirlpool Model# SF315PEMB1 - Oven takes a little while to ignite, once it does, the temperature is not accurate. If set to 350, it only heats to 275 (per oven thermometer) and when you adjust the temp to...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Oct 21, 2010 | Whirlpool Ovens
Older Maytag built in oven. starts and reaches desired temp, sometimes. Other times it never lites. electric igniter always reaches a glow
Even if the igniter glows... that doesn"t mean the ignitor is good. The igniter is wired in series with the oven bi-metal valve. Many times the ignitor will not allow the correct current to the oven valve for it to open... even though it is glowing. I would recommend replacing the ignitor first, you should be able to find one for under 40 dollars.
Aug 10, 2010 | Maytag Ovens
Oven is not working. When I set the temp. it does
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 03, 2010 | GE 30 In Freestanding Gas Range ...
No temperature control in Oven, even with a new thermostat
If you are certain that is wired correctly, and is the same as the old one, having made sure you have got the sensor located correctly,then it should click off the element at the set temp.
If it does not, then that leads me to suspect that the new stat is either faulty, or the wiring is not as it should be,I do not forsee any other reason for it not to cut out.
Jan 16, 2010 | Ovens
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ovens Logo
48 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
