Question about Cuisinart Coffee Makers & Espresso Machines
Cuisinart coffe maker does not allow water in
Does not pass waer to heating chamber
    Scholar:
  • 120 Answers
Common problem, it is hard water issue, these coffee makers do not handle even slightly hard water as deposits build up quickly blocking water flow to element. Try one of the many coffee pot cleaners, but if it is as bad as described, may not be enough to clean out coils.
CERACOAT-NANOTECH.com
Posted on Apr 21, 2015
SOURCE:
How do I fix water leak in Cuisinart ss700 coffee maker
if Cuisinart is like my bunn they do not have parts to fix , it is throw away and buy new .
Oct 12, 2015 | Cuisinart SS700 SINGLE SERVE BREWING...
The light goes on. I can feel the water is heated. Machine makes a lot of noise, but water doesn't pass from resivoir thru to frother wand or thru coffee filter. I am just running water to te
It needs to be descaled. After that, turn and try to make coffe but without the cofee. Turn on the steamer nozzle at the same time, that will draw the water to the coffee area, in fact try that first.
Dec 09, 2014 | Cuisinart EM-100 1000-Watt 15-Bar Espresso...
How do I clean my coffee maker?
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 22, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
The coffe maker is leakingout the bottom when the
Same problem here. The hose has a one way valve in it as well. I slid the hose part way off the reservoir connection and used the extra length to make up for the portion I cut off at the cut (you may have to move the on one way vlave further down the hose). This was intended as temporary fix while mywife bought a new coffeemaker. The new coffeemaker has been itting here six months as my temporary fix continues to hold.
Jul 04, 2010 | Cuisinart DGB-600 Coffee Maker
Water will not pass through seems clogged
Sometimes coffee grounds get into the intake if you don't use the intake filter. Unplug, set the pot aside and then turn the coffe maker upside down in a sink with a good hose sprayer. Direct the water up into the intake side of the coffe maker with the filter out.
Then refill and see if water will flow through. If it works, run vinegar or a pot of water with a tablespoon of dissolved baking soda (dissolve in pot first or it will clog the coffee maker).
It worked for me.
Apr 24, 2010 | Cuisinart DCC-1200 Coffee Maker
I accidentally ran a cycle without putting any water in the reservoir. Now the water will not heat up or flow through the filter. Did I kill it and if I did, is it cost effective to have it fixed?
You burned out the heating element. Depending on your warranty status and conditions, it will probably be less expensive in the long run to replace the entire coffee maker.
Nov 05, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart coffe maker self clean
I found the manual here http://www.retrevo.com/s/Cuisinart-DCC-1200-Coffee-Makers-review-manual/id/890ci052/t/1-2/
Oct 28, 2008 | Cuisinart DCC-1200 Coffee Maker
Russell Hobbs filter, cappuccino, expresso, steamer coffee maker
I HAD A GE CAPPUCCINO/EXPRESSO MAKER GIVEN TO ME WITH NO MAUAL OF ANY SORT THE MODEL NUMBER IS 169069. I REALLY WOULD APPRICIATE HELP WITH THIS THANK YOU...
Jul 14, 2008 | Coffee Makers & Espresso Machines
I just received my cuisinart coffe maker DCC1200 and I wanted to brew a pot of coffe but I am unable to open the glass carafe to obtain my coffe filters. Is there a specific way to open this? Your...
Hmm. Better late than never. Just got home with ours. Same problem. Called Cuisinart 800 number. Catch is on top of handle. There is a slight lip on each side there. Pop it up with pressure on both sides simultaneously. To replace, line up lid carefully with top of carafe and press firmly until it pops back on.
Jun 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
154 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
