Question about Car Audio & Video
How do I repair 12" sub coils? - Car Audio & Video
    Problem Solver:
  • 25 Answers
You can buy coils online ebay subwooferparts.com and fixmyspeaker.com. or look on youtube for videos of repair for your subwoofer. to take apart the sub use heat like a small torch lighter or low flame on a propane torch. use it on the frame of the subwoofer by/under the surround and spider but not all subs will be able to be taken apart whole. take the sub apart then use a calipers to measure the old coil so you know you buy the right size because it matters in fractions of mm to work or fit. good luck
Posted on Apr 28, 2015
Why is vacuum condenser light blinking
this is usually a leak in the evap coil,if it's under 12 years old the coil is still under warranty.sub zero is a great machine,the only problem is that the evap coil behind the back wall in the fridge section leaks or a hole develops.the freon leaks out and the fridge section will continue to get warmer,the vacumm coil lite will come on.i've seen this happen to some machines that are 3 years old it happens.you need to get a tech in,he'll recover the gas,evacuate it,replace the coil and add new freon in,if it's under warranty it will be 650 to 750,or if not under warranty 11 to 12 hundred dollars to repair.
Dec 29, 2011 | Sub-Zero 650 / O Bottom Freezer...
I have a Kicker Solo-Baric, L7, 12 inch subwoofer making a scratching noise. The cone is fine but the inside is not. Can i get this repaired? Kicker said no. This is a $250-300 sub. I hate to just throw it...
The bad news is that your voice coils could be fried up, basically mechanical failure. Might as well buy a new sub because replacing a voice coil means you got to rip the whole sub apart, very complicating.
Oct 15, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Can you replace the cooper coil inside a subwoofer sony xplod 12 inch
No sony doesn't not make repairable subs. I suggest avoiding sony xplod everything, they are nothing but problems. For subs try to go for Cerwin vega, rockford fosgate, clarion. The rockford fosgate is the best and when giving the power will tear apart your car and having you jamming all day long
Mar 22, 2010 | Car Audio & Video
Busted Kicker Subs
hi not worth fixing as labor is to high.
look around on ebay make sure you replace them with a name brand some companies like JBL sell refurbished subs with full warranties for cheap.
Remember with subs you must have a crossover either electronic or just a component in the cabinet so that the speaker is only reproducing the correct frequencies.
Lastly 12" subs require a ton of clean power 200 watts per ch minimum..and if possible they should be either 1 channel amps or bridged to 1 channel meaning for a pair of 12's you would have 2 amps
Contrary to popular belief most subs are damaged because people overdrive their amps and that blows the voice coil
hope that helps
Jan 24, 2010 | Car Audio & Video
Rockford 12'' P2 sub, stopped workin.
It sounds like you have a bad voice coil in the speaker.You can have the speaker rebuilt, but it is very expensive. People usualy only have very high end home speakers rebuilt, because then it is worth the cost. Hope this helped.
Aug 18, 2009 | Car Audio & Video
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Wiring the coils together
For each sub, tie the DVCs in parallel ("+"s together, then "-"s together). This will make the subs look like 2 ohms to the amp. Then, put one sub on each channel of the amp. That will put about 280W rms onto each sub, the max for the amp.
Mar 15, 2008 | Power Acoustik Power-Acoustik FUBAR-12W...
How to brige 4ohm 12"sub primire by prioeer double coil
You can't run TWO subs on the bridge!!!!! You will destroy the amp! Put ONE sub on EACH channel.
Sep 14, 2007 | Kicker KX400.2 Car Audio Amplifier
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
