Question about Garden
I have no electrical power to the ignition switch. The battery is good. I need a electrical wiring diagram.
    Scholar:
  • 120 Answers
Usualy a broken wire or shorted wire in harnass to ignition, and you should be able to follow it to starter solenoid and hot lead going to ignition switch, so use a meter to do a continuity test checking the positive wire, usually always red to ignition.
CERACOAT-NANOTECH.com
Posted on Apr 21, 2015
2004 Hyundai Tiburon interior lights work and button to unlock trunk works but no power windows, headlights or anything else the ignition is dead won't state on turn on for that matter. Please help
Do you know how to test automotive electrical circuits with a DVOM - digital volt ohm meter ? How to use a wiring diagram ? How to locate componets , electrical connectors that are inline of wiring harness , how to test a fusible link ? Do you know what a fusible link is . Start by viewing videos on youtube for basic automotive electrical testing . Electrical Troubleshooting Basics EricTheCarGuy < how to read a wiring diagram an if you don't know how to use a volt meter ,watch on that too . Electric Testing Techniques You Need to Know Look at a wiring diagram at http://www.bbbind.com/free_tsb.html Looking at the ignition switch diagram i see a fusible link supply's it with B+ voltage. . Check voltage at the battery - 12.6 volts is what it should be . pull the ignition switch , the electrical part .Check for B+ voltage on the orange wire ,terminal 2 Check the starting circuit ! Is there a anti-theft system light on ?
Mar 05, 2017 | Hyundai Cars & Trucks
Need electrical wiring diagramignition 1995 ford escort wagon
I wasn't sure what part of the ignition you wanted? Make sure battery has a full charge and battery connections all good. The diagram is for ignition switch. The top wires are voltage to ignition switch. The bottom wires are voltage from ignition switch.
Oct 20, 2016 | 1995 Ford Escort Station
Have a 99 Jimmy GMC when u hook battery up I can not get power to itintion switch fus box r inside if car period battery is good I mad sure of that
Do you know how to read a wiring diagram ? Go here http://www.bbbind.com/free_tsb.html free wiring diagrams . Enter your vehicle info - year , make , model , engine etc... Under system click on electrical distribution , then under subsystem click on power distribution .Then click on search , six blue links will pop up , click on them one at a time . See where ignition switch gets it's power . The ignition B fuse 50amp located in the under hood fuse box, supplies B+ voltage to the ignition switch .Plus Ignition C an ignition A fuse's also power ignition switch .
Mar 13, 2016 | GMC Cars & Trucks
Battery wont start the car ,ill charge the battery its ok for a few hours then its dead ,alt charging good ,battery is new,every fuse in both pannels are hot with key off please help
The battery dies after sitting for a few hours ? Parasitic drain on the battery ! With the key off all fuse's shouldn't be hot ! Bad ignition switch . Find a wiring diagram at www.bbbind.com an check power at ignition switch . Look on you tube , a lot of videos on basic electrical trouble shooting .
Nov 13, 2015 | Cars & Trucks
I need a wiring diagram for a 2002 chevy s10 4 wheel drive 4.3 for the starter to the switch
If the truck cranks over you have voltage at the ignition switch ! From starter to switch , First off starter to what switch ,ignition ? There is a 175amp fuse that supply's battery voltage to the power distribution center - fuse box under the hood . On the lower right side of the radiator support, below the battery !
Sep 10, 2015 | Cars & Trucks
Removed batteries filled and charged then reinstalled and motor wont crank(no power to switch and tilt) All fuses are good,I don't know where to look next ?
No power to switch? Turning key to on does not cause dash warning lights and gauges to turn on? Recheck battery connections and double check fuses.
If the switch has no power, could be a fuse or a fuse link. You can check the maxi fuses for power with a voltmeter or test light. Those maxi fuses would be hot at all times, so make sure all have power and are not blown.
A wiring diagram may help you figure it out. You can find one here for your vehicle: http://www.bbbind.com/technical.html
click on TSB's and wiring diagrams, free. agree to end-user license agreement, next page- click on Wiring Diagrams and enter vehicle information. Then you will pick the system and sub-system to view. I would start with System: electrical distribution. Sub-system: Power Distribution. Then you can see how the ignition switch gets power from the battery.
Jun 20, 2015 | Cars & Trucks
Will not turn over! Starter won't engage!!
When you turn the key to on, do the dash and warning lights come on? This would verify power to the ignition switch.
It's like this: you have a positive battery cable with a lot of juice connected to the starter, but not to the starter motor. It is only connected to the starter motor when the start wire out of the ignition switch energizes the starter solenoid, mounted on top of the starter.
So you check the small wire to the starter for power with the key held in start. If it has power then, the starter or the solenoid is probably bad- as long as the battery is charged and the battery connections and starter connection is good.
If you have no power on the small wire in start, trace the start wire back to the ignition switch. You may need a wiring diagram- there is often a start relay, a park/neutral safety switch with automatics or a clutch safety switch with a manual transm., and sometimes a "crank" fuse. All or some may be in the path of the start wire from ignition switch to the starter solenoid. You would need a voltmeter or test light to check this circuit. If you want more help, post back with make, model, year, and engine, and I could look at a wiring diagram for your start circuit, or I could post a link for you to see the diagram.
May 03, 2014 | Cars & Trucks
Why dont i have power when i turn my key on in 1991 ford bronco
Either power is not getting to the switch-check for an ignition fuse or a fusible link just off the battery-or power is not being transmitted through the switch-in that case, replace the electrical part of the ignition switch.
There should always be a hot wire going to the switch-it is hot at all times, just waiting to be sent somewhere through the switch to run, accessories, or start. First check if you have power to the switch. If not, may need to consult a wiring diagram, but likely a fusible link near the battery has failed.
Feb 01, 2013 | 1991 Ford Bronco
Need wiring diagram
Go to autozone.com and register they have good wiring diagrams for your truck.What I saw was all the relays going to ground so you should have 12V coming off the ignition switch.
Jun 01, 2009 | 1990 Ford F150
I need a wiring diagram for a 1985 ford f250 pick 4x4 truck and I cant find one online.
ok carmona, go to autozone website, enter your f-250 info, click on vehicle repair guide, then chasis electrical, then wiring diagram. Let me know if u have any trouble accessing the info. Good luck!
Dec 07, 2008 | Ford F-250 Cars & Trucks
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
