Question about Remington Garden
Oil not dispensing to the chain on remington electric chainsaw model # 107624-01 R
  • Garn Bugby
    Garn Bugby Apr 28, 2015
    The more I look at the design for dispensing the oil, the more I am convinced that it is a very poor design method!
  • Remington Master
  • 2,760 Answers
Number one reason I get saws in the shop with this complaint
> something stuck in an oil passageway! I use a small can of air to back flow the oil pump after I take off saw bar /chain , it does take a few moments of running saw to reprime it after doing this , and I completely dump out old oil from storage tank and clean it out real well
sawdust is most common thing I find in there
Posted on May 20, 2015
SOURCE: oil
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Posted on May 25, 2009
  • 188 Answers
SOURCE: Remington M15014AS Chain came off and I have no owner's manual
Here is a link to the instruction manual for a M14SC (the part number for the chain that will fit your saw) chain installation ... http://12.153.20.74/manuals/115038-01A.pdf . I hope this helps... If you need further instructions you can go online to http://www.remingtonchainsaw.com/.
Posted on Apr 21, 2009
firesnake09
  • 2923 Answers
SOURCE: Owners Manual for a Remington 2.5 HP 16 '' Chain saw, Model EL-7
Kindly check this link for manual. Please select the correct model:
http://lawnandgarden.owneriq.net/manuals/mfg/remington/remington_chainsaw_product_list.html
Posted on Apr 18, 2009
dontbother10
  • 2220 Answers
SOURCE: tighten chainsaw chain
There is a very in depth explanation in this Remington OM.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 25, 2010
  • 4088 Answers
SOURCE: how to put chain on remington electric chainsaw
Remove the side cover over the chain drive area. Remove the bar and clean the entire mounting area. Run the saw for a few moments to assure that oil is oozing out of the side port where the bar mounts. Lay the chain out on a bench or table and inspect it for sideways bending, damaged or missing links/teeth, and deformed drive teeth. Inspect the drive sprocket for damage as well. Clean the oil passages in the bar end including the two channels that go out to the chain groove. If all looks well, place the bar back into position and push it back. Fit the chain over the sprocket, then work it over the bar and pull the bar out to tighten the chain. Fit the cleaned cover over the case and make sure the adjustment tang drops into one of the large holes in the bar end--you may have to back off the adjustment screw several turns first. Fit the cover and tighten the mounting hardware finger tight. Make sure the chain cuts toward you on the bottom run. Tighten the adjustment screw until the chain pulls up to the lower bar edge, but still allows the chain to be moved by hand. Tighten the cover hardware and recheck the chain tension. Run the tip of the bar near some cardboard for a few moments--it should throw off a thin line of oil on the cardboard. Make sure the chain is properly sharpened. Hope this helps!
Posted on Jun 20, 2010
What kind oil do I use for the Remington 3.5 electric chainsaw
any good quality chain and bar oil. Available from your local garden and home store like Home Depot.
electric chainsaw oil Bing images
Sep 19, 2015 | Remington Garden
I have a 3.0 hp electric remington 16" chain saw what kind of oil do i use in it
Use bar and chain oil, not regular motor oil. Bar and chain oil has an additive especially for chainsaws.
Hope this helps. If it does, I'd appreciate your vote. Thanks for visiting fixya.com
Handie Andie
Apr 12, 2011 | Remington Electric Chain Saw
Remington 14" Electric Chain Saw Assembled 1.5 Peak: I just wanted to know what type of oil to put in t...
I have been using regular chainsaw oil and I think it works ok. I inherited one of these and would like to find a spare chain and also a manual. Can you give me any info? Thanks
Tim
May 17, 2010 | Desa International Remington 14" Electric...
Oil leak on Remington electric chain saw model #111174-01
check oil lines and when storing saw stand on end or on side blade up.. vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
May 13, 2010 | Remington 16" Electric Chain Saw
Remington electric chainsaw is leaking oil. How
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then clicked search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown"
It may help answer yuor question. RemingtonPower has production and replacement parts are very to find.
I've 7 chainsaws. 6 of them empty the oil tank overnight if I don't empty it. HTH
Lou
Nov 11, 2009 | Remington Electric Chain Saw
Need chain oil resevoir for Remington electric
I suspect you did an on line search, we can do no better. Remington has ceased production. Parts availability is limited to what is on hand. It might be advisable to save the money you would expend for parts and put it toward the purchase of a new electric saw.
Poulan has been in business a very long time and offers 8 different models. Some can be found at Lowes. HTH
Lou
Sooner or later you will encounter a part that isn't available for your Remington. Yours may be worth more as parts than as a complete assembly. eBay?
Oct 11, 2009 | Remington Electric Chain Saw
Oil
May 25, 2009 | Remington Electric Chain Saw
Remington chain saw oil problem
hi,
yes sounds as if you have gummed up the port for the oiler. you will need to clean the oil resevoir out using some kerosene or mineral spirits this will clean the port out and will not be harsh on the plastic. bar and chain oil is thick but has a sticky quality or viscosity that allows it to lubricate gas engines mor effectively and uses the heat from the engine to help thin it to a consistency to be of use to the bar and chain. on an electric chain saw there is not enough heat to allow this. a good oil resevoir cleaning and replace you oil with a light weight oil recommended this should do the trick. good luck hope this helped.
Mar 30, 2009 | Remington Electric Chain Saw
What type of oil do I use for a Remington Electric Pole Saw?
Mar 13, 2009 | Remington 16" Electric Chain Saw
Garden Logo
151 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
