When i turn on TV,have to exit the screen that pops up, then I have to go to the input and scroll all the way from TV to HDMI, can't I turn on TV will just go to the HDMI input
    Top Expert:
  • 10,875 Answers
Some tvs are made to turn on to the tv,yours is too,try to turn it off on hdmi and turning back on,did it work,if not,you will have to always change it,try only turning off with the remote and see if that works
Posted on Apr 21, 2015
    Master:
  • 456 Answers
Whatever it is that is plugged into your hdmi port will take over the tv ( sky dvd etc ) try turning the device off,turn your tv on,turn the device on. your tv should switch over to hdmi by itself and remember to ? hope this helps
  • Melissa Schweitzer
    Melissa Schweitzer Apr 21, 2015
    Thank you but doesn't work. Everytime I turn my tv off, I have to go through 3 steps with tv remote just to get it to HDMI input. It keeps defaulting to TV input.
  • jimmy jinx
    jimmy jinx Apr 21, 2015
    sorry i couldnt help.better luck with the other answers
  • 208 Answers
SOURCE: hdmi input not working
Sounds like a failure on the main or av pwb in the TV. Do you have another component such as sat. rec or cable box to try with hdmi?
Posted on Feb 05, 2008
VOTIT
  • 2071 Answers
SOURCE: menu screen won't go away.
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
DON'T FORGET TO RATE;
Posted on Sep 07, 2008
  • 90 Answers
SOURCE: Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Posted on Jan 14, 2009
  • 159 Answers
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Posted on Apr 24, 2009
wthead1
SOURCE: Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Posted on Aug 22, 2009
Our screen turns blue and goes to new devices input. We have nothing else connected to tv except Brighthouse cable box. If we push the exit button on the tv remote it then goes to showing a cable box and...
Your TV probably has multiple "inputs" (coax, HDMI, component, et cetera). Use the "input" (or "source") button on your TV to cycle through all those available "input" streams.
If you select "coax", and there is *NO* coax cable connected to the back of the TV, you *WILL* see the "blue-screen". Select a different source that is "active".
Feb 24, 2015 | Televison & Video
Roku stick dosent do anything. ...? Plugged into hdmi slot on tv and also plugged in power cord to roku and nothing pops up on my tv...? Iv tryed to reset but dose nothing. ... help???
Did you change the TV input setting on your TV to the correct HDMI input? Most Televisions will take a few seconds to scan the input before displaying any image. Most newer televisions have multiple HDMI inputs, and you might need to select each one, wait several seconds to see if there's a signal, and then move on to the next input, until you find which HDMI input has the Roku start screen signal.
Dec 09, 2014 | Televison & Video
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more: http://www.ehow.com/how_4840499_turn-hdmi-input-sharp-tv.html#ixzz2a6Xat0JU
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
When tv is turned on video 1 shows up on screen.How do i get tv channels
Hit INPUT on the remote and scroll up or down with remote arrow keys to find TV or HDMI for HD. -Nic
Jul 29, 2011 | Sanyo Televison & Video
View mode changes when switching tv off then on
If this is the correct tv model number LC42D62U and if you are connecting it to something with an hdmi cable, and it is on one of the hdmi inputs then you need to change the settings. Press the menu button--->scroll to setup on the right--->scroll down to hdmi setup and press enter to select--->If auto view is not highlighted already highlight it then press enter--->disable it then press enter--->press exit or menu menu to exit
Apr 23, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The "new device found" screen keeps popping up
Inspect for damaged pin on INPUT 1 socket. (left most of the three HDMI connectors)
A quick pull on the cable can damage the pins.
=== If you see mis-aligned pins then please power off the set before making corrective action. ===
============== Here's a textbook instruction from Mitsubishi
If the New Device Found Screen Displays No HDMI Control Option If the New Device Found screen shows no option for HDMI Control, one of these conditions applies: • HDMI Control is turned off in the menus of the new device Action: a. Highlight EXIT and press ENTER to close the New Device Found screen. b. Display the device's setup menus and enable the device's CEC capabilities. c. Wait for the TV's New Device Found screen to appear again. d. If the New Device Found screen does not appear, power off the device. Power on the device and wait for the New Device Found screen to display with the HDMI Control option.
Next time you see the NEW DEVICE FOUND screen pop up.
Toggle the CEC field (on the right side of the pop up) to OFF.
Jan 05, 2011 | Mitsubishi WD65737 65" DLP TV
Samsung PN58b530 tv and harmony 550. When setup have all devices set except when the tv turns on it stays on one hdmi setup then jumps to another that was not programmed.
Samsung TV's have Anynet automatic input switching. This severely conflicts with the Harmony Remote as they both do the same jobs; Switch inputs automatically. We would like for you to disable this feature on your Samsung TV using your original remote, so the Harmony Remote will work properly.
Disable Samsung Anynet+
1. Press your Tools Button.
2. Scroll down to Anynet and press your Select Button.
3. Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4. Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote.
Feb 01, 2010 | Logitech Harmony 550 Remote Control
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
