Question about Cameras
How can I open the battery compartment? - Cameras
    Top Expert:
  • Cameras Master
  • 45,245 Answers
Usually by sliding the cover in the direction indicated on the outside of it . but no make no model no help can we look for
Posted on Apr 21, 2015
Testimonial: "I have an iE090 Polaroid underwater camera. I already tried sliding the cover, it just won't open"
  • ray gallant Apr 21, 2015
    then contact polaroid .com support
  • Anonymous Apr 21, 2015
    I managed now, I found the trick! Thanks anyway
Can open my trunk doesn't work with remote or from inside of glove compartment thanks 2005 ssr chevorlet
Rear Compartment Lid
The rear compartment lid can be opened by operating the rear compartment lid release switch, located on the instrument panel, or by using the manual release located on the rear compartment lid. Battery voltage is supplied to the rear compartment lid release relay through the Main Power fuse. The roof and door module (RDM) receives the rear compartment lid release request via the rear compartment lid release switch signal circuit. The RDM grounds the rear compartment lid release relay coil when a release input is received through the instrument panel (I/P) switch. Grounding the coil causes the rear compartment lid release relay to energize, providing power to the rear compartment lid latch assembly through the rear compartment lid release actuator supply voltage circuit.
As an alternate method of operating the rear compartment, an emergency release handle is accessible from within the rear compartment. When the handle is slightly pulled, it will provide a ground for the bed cover release relay which will cause the actuator to operate and open the rear compartment lid. If the handle is pulled further, it will mechanically open the lid, so even if the battery is discharged or there is an electrical concern, the emergency release handle will mechanically open the lid.
Jan 01, 2017 | Cars & Trucks
Open battery compartment
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
Oct 19, 2013 | Nikon F601 35mm SLR Camera
Battery release latch won't open
If you push the battery in and try to release? Try a little silicon spray, mind not to over spray.If you hold open the release switch and manually pry out the battery with your finger nails?
Nov 12, 2012 | HP Computers & Internet
Cannot open battery compartment on Sony Cybershot rmt-dsc1 remote
@ Frans Bedford-Visser
On the right side of the battery compartment you can see some vertical plastic lines. Pull those towards the compartment. Simultaneously open the compartment as indicated by the arrow. It will open. Took me a while to figure it out but it works.
Jan 08, 2012 | RCA DIRECTV Satellite Remote Control
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    Opening battery compartment on Midland LXT80 2-way radios
    First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
    Jul 07, 2010 | Midland LXT80 Two Way Radio
    Need to replace internal clock battery
    This may have been solved by now however...
    REMOVE MAIN BATTERY... Before Opening any compartments!
    The CMOS battery is located in the modem compartment.
    Place the unit upside cown with the rear connectors facing towards you. It is the compartment on the right rear corner (i-screw to remove). It may be difficult ro open due to the modem labe sticking to the cover. Use care when attempting to pry door open.
    Battery is CR1220 0.5in Diameter (Dime Size) (40mAh Rated).
    Alan
    Feb 22, 2010 | IBM ThinkPad 390X 2626 Notebook
    Battery compartment in Magellan SporTrak
    I used a Dremel Tool with a small drill bit to drill it out without killing the threads. It then popped out. My only problem now is finding a screw that fits the threads....
    Jan 28, 2009 | Magellan SporTrak Map ATV GPS Receiver
    I can't open the battery compartment
    Had same problem. Try pressing the heel of your hand on the battery compartment lid and rotate. Worked for me.
    Dec 27, 2007 | RCA WHP141 Consumer Headphones
    Cassette am
    To unload the videocassette from the cassette compartment, the camcorder needs to be connected to a power source (either an electrical outlet or a charged battery). Please refer to the following instructions. Connect the camcorder to the power source or insert the fully charged battery pack, and then slide the EJECT switch to open the cassette compartment cover. The cassette compartment cover will open, and then the compartment will open automatically.
    Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
    Cameras Logo
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
