Question about Makita Saws
My Makita 6400 petrol saw stopped running , when I pressed decompretion button and tried to start loads of petrol came out of it, help!
    Sergeant:
  • 192 Answers
Where did the petrol come out from? The tank lid or the muffler or somewhere else?
Posted on May 11, 2015
stug_57u
  • 99 Answers
SOURCE: makita 6410 petrol disc cutter
First of all, make sure you have followd the correct start up procedure.
(1)Throttle on and locked in start position, (2)choke on and pull a few times. Saw should fire briefly and cut out. (3)Now switch to idle (half choke if applicable) and pull another couple of times. Saw should now fire and run. If you have pulled it too many times in the full choke position you will have flooded the engine. To rectify this you will need two people. One of you should hold the machine steady on the ground with no choke on and throttle fully open. The other should also steady the machine and pull the starter in quick succesion. This could take ten or so pulls but it should start the engine in the case of flooding. Sometimes it will splutter a couple of times before fully starting and it will normally bog down a bit for the first few seconds as it spits out the excess fuel/oil mix.
If you got to point (3) as it shown above, and then the saw wouldn't start, or hadn't fired and died then there could be a few different problems. basic checks are for, clean filter, fresh/clean fuel, clean spark plug (ie, not oily/choked with carbon build up). When checking the spark plug, if it has fuel/oil mix on it then ther is probably aeither a compression problem/air leak or no spark. To check for a spark leave the plug unscrewed but fitted into cap, rest it against a metal part of the saw and pull the starter with the elec switch on. You should see a healthy blue spark. WARNING, do not rest the spark plug near the plug hole as if it does spark it could ignite any fuel/oil mix that is pumped out of the cylinder. I've had many a singed eyebrow from this happening. If there is no spark, check to make sure the cap is attatched securely to the lead,and try repacing the plug. If this doesn't help you will need to get the coil, ht lead and wiring tested.
Posted on Nov 01, 2008
picatudo
  • 239 Answers
SOURCE: i have makita petrol stone cutter.it starts but wont take revs
it needs more gas adjust the screw on the carburator
Posted on Feb 07, 2009
SOURCE: Makita Saw blade brake doesn't work.
i have a makita still saw put i pull cored but it dose'nt start
Posted on Jan 21, 2010
  • 304 Answers
SOURCE: I bought a used Makita 2414b chop saw. Plugged it in and cannot find the power button to engage the blade?
There should be a small black button on the top of the handle which you have to press at the same time as you pull the switch.It is always getting lost. If it is there and the motor runs but the disc doesn't then the gears could be stripped.
Posted on Jun 19, 2012
  • 304 Answers
SOURCE: Makita Saw Bss610 stopped
It might be that the brushes have got stuck in the brush holders. Take them out and make sure they run free.
Makita MLT100 table saw when stop button is pressed the motor switches off saw seems to be running really roughly and the the blade takes an age to stop spinning. Normally blade stops really quickly.
I can't find this saw at Makita; so, generally. Follow all safety precautions. :-)
If the saw is running rough, the first thing I'd check is the brushes for the motor, especially if it has any age. These are fairly inexpensive and will solve a lot of woes. The next thing would be to check the thumb switch, if it has one. This is the switch that allows you to pull the trigger to run the saw, if it's just a button, then check the actual trigger switch to make sure it's working properly as it probably, not always, also engages the brushes to reverse the motor for a second, to slow it down so it stops faster.
So, check the brushes on the motor, if they show any signs of wear, it's probably them. 2nd, check the switch. Please let me know and if I've helped, give me a vote up. Thanks.
May 18, 2017 | Makita Saws
My makita dbc4010 petrol strimmer was working then not used for 3 months now it wont start,plus now theres no spark
Parts: http://www.ereplacementparts.com/makita-dbc4010-brush-clearing-saw-parts-c-97_16558_10177.html?gclid=CKyA0JLti80CFQetaQodzw0DaQ Use fresh gas and oil, 2 stroke 40:1. Clean/replace air filter and spark plug.
Sep 25, 2015 | Makita Garden
Jun 17, 2012 | Makita Saws
Makita petrol stone cutter
Start by removing the wire from the cut out switch to rule out a problem with the switch, if still no spark with a new plug it will be a replacement ignition unit.
Feb 12, 2012 | Saws
MY MAKITA DPC6410 PETROL SAW IS RUNNING SMOKEY
It uses 2 stroke oil during combustion as it is a 2 stroke powered engine..Sometimes it may be a small deposit of oil and the bottom of the gas container which causes this smoke or else you may have added a bit more oil than needed in the fuel..I assume it is a 2 stroke engine and also note these do give out a little bit of smoke..
Dec 08, 2009 | Makita DPC6410 64cc 12" Power Cutter
Saws Logo
320 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
