Question about Avaya 9611G
How do I get our Avaya 9611G phone to reboot?
Hey there, we have this phone in our office and it was logged out incorrectly. It now is just showing "Discover" and 8 numbers underneath. Is there a quick way to get this up and running?
4 Suggested Answers
  • 33 Answers
SOURCE: Blank Screen
Try changing the connection on the ethernet switch like the cisco switch if you are you using power on ethernet...
Posted on Dec 11, 2008
  • 10 Answers
SOURCE: Avaya assighning New static IP address after IP address conflict
If you need to reconfigure the phone press "mute"RESET# where the alphabets correspond to the digits button they appear against on phone. E.g. for R press 7... and so on ..... then the phone will ask reset values? press # to reset and reboot the phone. Then key in the correct IP address for phone .... call server IP address ... router .. files server .... VLAN ID etc ....
If all the settings are done correctly ... and if the phone gets the reach ability to the call server it will work fine...
if you are unsure of these settings.... go to the menu and network options of any working phone and get the correct values from there
Posted on Apr 02, 2009
  • 10 Answers
SOURCE: How to configure Avaya's IP Phone 5610?
Ensure the reachability of the call server from that port. To ensure the same, configure a laptop with the IP address and default gateway of the intended IP phone. Then try pinging the call server from the laptop.
If this works then the setting should work for IP phone too. Double check on the router IP address and Vlan ID configured on the phone.
Why doesn't my 9611G phone ring when someone calls
turn the profile to normal and the ringtone to a loud one. make sure the volume is up. ensure there are no diverts set.
You can reset to factory default and setup from scratch if you have difficulties locating the error
Jun 30, 2015 | Avaya 9611G
How to delete messages?
For most of the Avaya mail systems it is *3 after you have logged into your voicemail. If this is incorrect just listen to the prompts in your voicemail it will tell you.
May 14, 2014 | Avaya Corded Phone avaparp18d
How to change exetension no in ip phone 9611g
If you have an ip phone i suppose you are in an office environment - please contact your system admin to help change the extension
Oct 23, 2013 | Avaya 9611G
Change time
You need to log in to the system administration. Unless you have a button programmed called "self administer". If you do, press that. If your system admin has allowed you to change the time, you will see a button labeled time...
May 22, 2013 | Avaya 9611G
4610sw avaya phone is showing in discover mode
Most often I have seen phones sit at discover when there is a hardcoded address on the phone. I would suggest clearing the phone. To do this, press * when prompted during booting. Password will either be nothing (just press #) or CRAFT. If it is incorrect, the phone will reboot. If successful, the phone will enter the settings. Once in settings, press # repeatedly until you reach the "Enter Command" prompt. At that point, enter MUTE button CLEAR (25327) and #.
Best of luck from Macondo Networks
Jan 29, 2011 | Avaya 4610
I need to reset my avaya 5410 voicemail password and I do not know the current password. please assist
You will need to log into Mnager (the IP Office management application). Go to the users section, and click on the Voicemail tab. delete the stars. Then save the config.
When you log in the first time, there isnt a password, so just hit #.
Jan 12, 2010 | Avaya 5400 Series 5410 Phone
Blank Screen
I would verify what the firrmware is of the phone. It is possible that the phones need to be upgraded.
Mar 27, 2008 | Avaya 5610 IP Phone
Avaya 9611G Logo
237 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
