Question about Dirt Devil M085807HD Bagless Upright Vacuum
Vacuumed dirt does not enter container. Dirt spews out when turned off.
  • Dirt Devil Master
  • 932 Answers
Vincent,
More than likely you have a clog some where so that it does not pull the dirt all the way to the hopper. I would check hoses and filters and any tubing from the floor attachment all the way to the dirt container. Hope this helps!
Posted on Apr 22, 2015
Dirt devil easy lite. I vacuumed up a coin I think, the vacuum is now screaming.. How do I remove whatever it was that got vacuumed up?
The coin may have broken the fan. You will need to inspect it to see if the coin may have gotten stuck somewhere causing the noise. Inspect the fan for damage.
Feb 18, 2015 | Dirt Devil Easy Lite Quick Vacuum
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
My dirt devil wont turn on
first thing to do is to look in the dirt container for what masy have been sucked up.
Nov 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
There is no suction, even though the container is empty
Your hose is clogged and needs to be cleared. You may have to remove one or both ends of the hose that connects the dirt to the container.
You might have success trying to "back vacuum" the hose. A broom handle is sure to clear the clog, however.
Thanks for posting at FixYa.com
Dec 13, 2009 | Bissell 3576 CleanView II Bagless Upright...
What causes a vacuum to make lots of dust and throw back out what it vacuumed
It sounds like the airducts that lead to your dirt chamber are clogged. The dirt can't get through to the dirt cup so it spits it back out and blows dust everywhere.
Nov 27, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Dyson dirt collector base won't click shut--gasket?
HI,
IS THE BASE OF THE WASTE BIN ATTACHED OR HAS IT SNAPPED OFF?THE BASE OF THE WASTE BIN JUST CLIPS BACK ON THE ONE END SO THAT IT CAN SWING.IF HOWEVER THE BASE IS ATTACHED BUT WONT STAY SHUT OR LOCK THEN ITS POSSIBLE THE LATCH INSIDE THE CYCLONE HAS SNAPPED OFF.IF ANY " DIRT CHEAP " ( EXCUSE THE PUNN )SPARE PARTS AR REQUIRED THEN PLEASE FEEL FREE TO EMAIL ME DIRECT: DYSONLOGISTICS@AOL.COM
Dec 31, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dirt Devil M085807HD Bagless Upright Vacuum Logo
56 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
