Question about Diamond Pacific Tool Corp Diamond Pacific VT-12 Heavy Duty Vibra-Sonic Vibrating Rock Tumbler
To see how motor and v-belts go together - Diamond Pacific Tool Corp Diamond Pacific VT-12 Heavy Duty Vibra-Sonic Vibrating Rock Tumbler
Haier 6.5 current ft dryer, how do you put the belt on after it came off?
if its still wrapped around the drum an drum turns with it fine .. see the white idler belt goes on bottom then around the motor idler.
take the right side of belt an pull it around motor an down an under the idler .
Oct 12, 2014 | Dryers
Timing belt went.
At highway speeds it may have bend some valves, is this a 4cyl engine or a v-6? this all depends on the mileage and the condition of the car, the cylinder heads would need to be removed and valves replaced plus a new belt and waterpump and timing belt pulleys, this is costly, if its a 4cyl it maybe worth tryying a belt and see what happens, that dont have to put it all back together they can run the engine with a new belt and if you got lucky then put it back together.but if its the v6 engine i would not try just junk it, sorry or replace engine if car is worth it.
Dec 06, 2011 | 1999 Toyota Camry
Drum stopped spinning. I took apart and took out the broken belt. Not positive if thats the only problem. I found a one inch in diameter plastic piece that seems to be broken, also. Not sure how to put it...
The plastic piece maybe the pulley on the end of the motor. Check the motor for a drive pulley it will have grooves in it for the belt. Since you are in there check the idler pulley for ware, the drum support pulleys in the back for ware, and see if you have any glide pads for the front of the drum. When you put it together put the belt around the drum before you put it in. Before you secure the front of the drum put the idler pulley on the belt. As long as you do not end up with extra screws you got it back together right.
Jun 01, 2011 | Dryers
Loud sqeeling noises when running. Sounded like a belt slipping. Dryer died all together and smells of burning rubber. Suspect a loose or broken belt. How do I change it?? --Dave
Check and see if the belt slipped off the motor pulley broke or wrapped around motor pulley. Check the idler pulley (large white wheel end of motor) Loose?
Oct 16, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag washer lat9416aaq belt slips in spin cycle put new belt on and springs
The motor is supossed to walk up the belt to let it slip enough so the pump can run and drain out the water before the drum spins at full speed( that's why it's spring mounted).
Check the pump belt, it should be snug but not tight, you should have some give when you squeeze the belt together, but it should not touch together. Don't use any belt dressing on it, it needs to slip. Make sure the washer is unpluged before you do anything.
Feb 05, 2010 | Maytag Washing Machines
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Beater Bar Belt loose and bar won't turn
Provided that the motor isn't loose, the belt should fit tightly. If you had reassembled the beater bar back in the vacuum improperly, the belt would be tighter, rather than looser. If you are sure that the motor isn't loose and the beater bar was reinstalled correctly, then either tha belt slipped back off the motor shaft, or they sold you the wrong replacement belt.
Jul 18, 2009 | Hoover U6630-900 WindTunnel Bagless...
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
Tricity Bendix Condensor Dryer
the belt needs to go over motor rod first this means you have to take cover off then release the spring that attached to the motor so there is some play with the belt ,then pull the belt around the drum,quiet tight but you can do it,then pull the motor spring back into position to tigthten the belt put back together.... job done
Jan 19, 2009 | Tricity Bendix TM310W Electric Dryer
Savvy vacuum belt
It is easier when you also take the top off. Then you can put the belt over the roller and re-install it, then put the bottom plate back on, then turn it over, undo the motor and put the belt on the motor pulley, re-install the motor and put the rest back together. To remove the top, thewre are a couple of scres from the bottom, then from the top, remove the Hoover emblem, there is a screw there to remove and the top will come off.
Jul 11, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Diamond Pacific Tool Corp Diamond Pacific VT-12 Heavy Duty Vibra-Sonic Vibrating Rock Tumbler Logo
264 people viewed this question
Top Diamond Pacific Tool Corp Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Diamond Pacific Tool Corp Health and Beauty Expert? Answer questions, earn points and help others
