Question about Garden
Will mot stop on off button
Had to remove spark plug cover ?..
  • 2,044 Answers
Sounds like a bad switch that needs replacing. See if all the wires are in place on the switch. If one has come off or come apart that would do it as well.
Posted on Apr 21, 2015
Oil leaking on spark plug
If the spark plug is oil fouled, you either have leaking valve seals, or bad piston rings. Bad rings would be accompanied by excessive blow-by. With the engine running, remove your oil filler cap. If there is air pulsing out of the filler tube, it your rings. If not, it is your valve seals.
Jun 15, 2016 | Cars & Trucks
Starter rope grabs at times. why?
try using the de-compression button when starting, will do the same as removing the spark plug but without removing the spark plug.
Failing that, remove the starter cover and check starter cord for daage or signs of snagging.
Feb 03, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Engine oil in cyliders with spark plugs
it means that the rubber gasket and the rubber seals on the spark plugs got hard and allows oil going through to spark plugs.What you have to do? If you know how,remove the rocker cover and renew the gasket and the seals for the spark plugs and your problem stop to exist.
Sep 17, 2012 | Ford Escort Cars & Trucks
1999 Audi A6 Avant 2.4L V6 30V (petrol) Oil leak. When i came to do a spark plug change, each spark plug tube was full of oil, and the spark plugs were covered. When the spark plugs are taken out, all of...
May be totally unrelated but I had the same issue on a 95 civic. It has "spark plug seals" that needed to be replaced. Dealer did it for about $250.
Oct 02, 2010 | 1999 Audi A6
2003 cadillac cts - white smoke after replacing spark plugs
it will byitself just drive it a bit. the valve cover seals or plug tubes need replacing
May 29, 2010 | 2003 Cadillac CTS
How to change spark plugs on a 4cyl 2005 kia sportage
Inspection
Inspect the spark plug tip for wear and damage. If the tip is covered with carbon, replace the plug. Do not drop or shock the spark plug. If the ceramic body is broken replace the plug.
Fig. Spark plug inspection points
Removal & Installation
WARNING Do not attempt to remove spark plugs when the engine is hot.
  1. Disconnect the negative battery cable.
  2. Remove the air intake hose assembly.
  3. Remove the accelerator cable bracket.
  4. Remove the six bolts and coil cover from cylinder head cover.
  5. Remove the four bolts and the two coils from the cover.
  6. Disconnect the high tension leads from the spark plugs by twisting the boot and removing.
  7. Use compressed air to remove any dirt from around the spark plug hole.
  8. Make sure the spark plug socket fits squarely on the spark plug, and then remove.
To install:
  1. Be sure the spark plug gap is set to 0.039-0.043 in. (0.98-1.09mm).
  2. Apply anti-seize compound to the spark plug threads.
  3. Carefully install the spark plug into the cylinder head and torque to 11-17 ft. lbs. (23 Nm).
  4. Reconnect high tension leads.
  5. Install the two ignition coils and torque four mounting bolts to 14-19 ft. lbs. (26 Nm).
  6. Install the coil cover and secure with six bolts
  7. Install the accelerator cable bracket.
  8. Reconnect the air intake hose assembly.
  9. Reconnect the negative battery cable.
Have a nice day. Good luck (remember rated this help)
Mar 05, 2010 | 2001 Kia Sportage
Car failed MOT on emissions yesterday but after a
Several things.....
EGR Valve
Bad Spark Plugs
Bad EVAP Canister.....
All related items to fuel and spark.
Do you have bad fuel mileage? How does the engine run? Smooth? Chugs? Idles rough?
Oct 01, 2009 | Daihatsu Charade Cars & Trucks
How to remove spark plugs
Remove 6 10mm bolts holding spark plug cover on valve cover. Then once cover is removed, pull off spark plug boots and use 16mm socket to remove spark plugs. Thanks
Jun 08, 2009 | 2001 Daewoo Lanos
Spark plugs 24v v6 sri 200 vauxhall vectra!!!!
On vectras they are hidden under a black plastic cover ontop of the engine, but you don't need new plugs for the mot
Feb 23, 2009 | Alera Technologies Cruiser (270118)...
Oil leaking out of valve cover gasket
It is a Valve Cover Gasket. You can get a new one at any Auto Parts Store. To make this repair last longer, Do not get the Cheap one, Get a Felpro Gasket and it will Quadrupel the Gasket Life. Please Rate My Response! Thanks!
Jan 30, 2009 | 2001 Kia Sportage
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
