Question about Xerox Office Equipment & Supplies
Errow 010-333 on xerox 7132. - Xerox Office Equipment & Supplies
  • 2072 Answers
SOURCE: how do i activate scan
The Scan to E-mail feature provides the ability to scan and send a document as an e-mail attachment.
NOTE: The Scan to E-mail Kit is required to enable the Scan to E-mail feature. The kit contains a License Agreement, installation instructions, and a password.
You must be a System Administrator to perform this solution.
To enable the Scan to E-mail feature:
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm]. The System Administrator Menu screen will be displayed.
  5. Select [System Settings] twice. The System Settings screen will be displayed.
  6. Select [Common Settings]. The Common Settings screen will be displayed.
  7. Select [Maintenance / Diagnostics]. The Maintenance / Diagnostics screen will be displayed.
  8. Select [Software Options].
  9. Select [Keyboard].
  10. Enter the password contained in the Scan to E-mail Kit using the keyboard on the Touch Screen, and then select [Save].
  11. Select [Reboot]. The machine will automatically power OFF, and then power ON.
  12. Enable the Scan to E-mail port settings. See the Related Items below. After the port settings have been enabled, the E-mail option will be displayed on the Touch Screen.
Posted on Jul 30, 2008
  • 2072 Answers
SOURCE: fault code 010-333 xerox 7132
Most likely you will have to have the fuser replaced. That is an overheat problem. You may just have a piece of paper wrapped in the fuser shutting it down. You can open the left hand drawyer adn remove the fuser , check inside it and put it back in and see if that clears.
But, more than likely you will have to put in a new fuser.
Posted on Aug 13, 2008
  • 24 Answers
SOURCE: i need the diferences between
Pretty vague question.
The Doc 12 probably has a Fiery Network controller, while the 7132 has a Fuji/Xerox controller.
The Doc 12 would have limited scanning capabilities while the 7132 can, depending on the config ordered, scan to E-mail, SMB, FTP, Scan to PC, and scan to a mailbox on the Xerox itself. If you have an embedded fax in the configuration, you can set it to catch incoming faxes and forward to e-mail, or a SMB or FTP folder on your PC or server.
The 7132 is rated at 8 pages a minute in color mode, and 30 pages a minute b&w.
The Doc 12 has been around since 2002, the 7132 is about 3 years old and has been replaced by the 7232.
Posted on Jun 25, 2009
duane_wong
  • 6826 Answers
SOURCE: The Windows 7 mini drivers for the Xerox 7132 only
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=WC7132&ripId=&Xtype=download
The above is the XP Vista drivers for the 7132.
The 7232 is a totally different machine and the windows 7 drivers for it will not work with your 7131 according to their table.
Also, according to Xerox's table, windows 7 drivers are definitely not available for the 7132. The latest drivers are for Vista, but that's not necessarily a bad thing, because windows 7 can run vista programs in its compatibility mode, or many times it works alright after downloading and installing the vista drivers.
Hope this helps!
Posted on Jul 14, 2010
emissionwiz
  • 76691 Answers
SOURCE: 089-311 error code for xerox copier #7132
The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor
Posted on May 01, 2012
How to clear error 10-333 on xerox 7132 all in one
That error signifies a fuser problem where the thermistor does not detect the fuser coming to temperature. Need to replace fuser unit, part number 008R13022, see link.
http://www.iteminconline.com/008r13022_008r13022-xerox-workcentre-7132-fuser-110-volt.htm?source=froogle&gclid=Cj0KEQjw8u23BRCg6YnzmJmPqYgBEiQALf_XzZg4C5Qd7jYhL14rJSJWIPdkZdVrtP4kPg2RlOQFweIaAnzV8P8HAQ
Apr 26, 2015 | Xerox Office Equipment & Supplies
Xerox 7132
You can find drivers for this and many other models at: www.xerox.com/support
Enter the 7132 in the "Search or Choose" box.
Windows Vista 64 bit:
Limited Functionality PC driver support. This driver "should" work on most Windows 7 64 bit machines loaded locally, but it is NOT supported.
Windows Vista 32 bit:
Full Functionality Supported PC Driver limited to 32 bit Windows Vista or older operating systems.
Mac 10.5 or 10.6 ONLY.
Sep 29, 2013 | Xerox Computers & Internet
Xerox 7132 printing dots after 35 pages
Check if it is with just one document or with all documents. Can also be coming from the job and not the printer
Apr 07, 2013 | Xerox WorkCentre 7132 Multifunction Color...
The Windows 7 mini drivers for the Xerox 7132 only provide a limited feature set. If I install the Windows 7 driver for the Xerox 7232, will it work with all features on the Xerox 7132?
Hope this helps!
Jul 14, 2010 | Xerox WC7232 Printer
I need the diferences between docucolor 12 and xerox 7132? please
Jun 23, 2009 | Xerox DocuColor 12 Color Copier
79 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
