Question about Ricoh Aficio CL3000 Laser Printer
How to load paper into it
Ive tried in the front compartment but I really don't know what I am doing
  • Ricoh Master
  • 2,825 Answers
Most laser printers have a paper tray at the bottom. You pull the tray out, and put paper in the tray.
Posted on May 14, 2015
MY DEL DESKTOP 531 THE DISK CLEANUP HAS NOT BEEN WORKI NG & MY BACK UP HAS NOT BEN WORKING AS I CAN NOT DELETE OR KNOW WHAT TO DELETE BUT I CAN'T DO THAT NOW
Wow! Where to start? First of all if the computer has Windows XP loaded on it that is no longer supported by Microsoft. If you want to re-install an OS (operating system software) I would suggest Windows 7.
May 10, 2013 | Dell Inspiron 531s Desktop Computer
Softener wont add
Please ensure the machine is turned off at the power socket before you do anything.
Have you tried removing the draw? If you pull the draw out on most washers and slightly tilt the draw up and then try and pull further out the draw will come out. (DO NOT USE BRUT FORCE) if it doesn't come out easily then it probably isn't designed to.
If you get the draw out give it a really good wash in hot soapy water, the compartment where the softener goes normally as a piece of plastic that lifts up so you can clean the compartment throughly. Whilst the draw is out also give the inside of the draw compartment a clean out. (PLEASE ENSURE THE POWER IS OFF) Just for safety.
Once you have cleaned the draw replace it and try a full wash and see if that cleared the problem.1_15_2013_10_08_16_pm.jpg
Jan 15, 2013 | Belling SGE12X Front Load Washer / Dryer
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
I have a Lexmark x2600 printer and when I stated printing many pieces went through and then jammed and won't move in either direction, the paper is really jammed in and I don't see any way to get...
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Tips: Use only paper that is in good condition. Fan the paper before loading into the feeder to prevent sticking together. Use the specified media type and sizes for your model. Don't overload the feeder.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
Dvd player seems to be stuck when loading dvd wont go any further
On the front of your DV player, there is a compartment where the DV is placed. Check to see if there is a little hole in the front of that compartment. If there is, take a paper clip and expand the ends. Place the end of the paper clip in the hole and move it around and into the hole. This should release the compartment drawer to open.
If the drawer is stuck- half way out, do not force. There is a small band that directs the opening and closing. Forcing it will break it. If this has not helped, relate to the manual.
Hope this has helped. Dana
Dec 31, 2010 | Televison & Video
Want to know how to load thermal paper on my sharp Fax model FO-71
1 - Grasp the finger hold and pull up to open the operation panel.
2 - Flip up the front paper guide.
3 - If you are loading paper that is 210mm in width, place the paper roll shims on each side of the paper compartment. (Note that Sharp recommended paper, including the initial roll, is 216 mm in width.) • The ribbed side of the shims should face in (toward each other).
4 - Unwrap the roll of thermal paper and insert the paper shaft.
5 - Place the roll of thermal paper in the compartment, making sure the ends of the paper shaft fit into the notches on each side of the compartment.
• Important: The roll must be placed so that the leading edge of the paper unrolls as shown. (The paper is only coated on one side for printing. If the roll is placed backwards, the paper will
come out blank after printing.)
6 - Insert the leading edge of the paper into the slot as shown. Continue to push the paper through the slot until it comes out the opening in the front of the machine.
7 - Make sure the paper comes out straight, and then flip down the paper guide.
8 - Close the operation panel, making sure it clicks into place.
• FO-71: A short length of the paper will be cut off.
Dec 01, 2010 | Office Equipment & Supplies
Loaded paper not going through
Annie, did you try to feed it one paper at a time? in many printers the feeder doesn't do a good job separating one paper from the rest.
another thing you can do is to turn off the printer and back on. this might get it out of the stuck status it is in.
did you check there isn't any paper stuck in the feeder?
Mar 10, 2010 | Lexmark X5470 All-In-One InkJet Printer
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Does the draw compartment come out inside
Remove any parts that you can in the drawer itself ,and thoroughly clean all pieces., and poke wire through syphon tube, to make sure it is clear.
In the drawer compartment get a stiff nylon brush and clean all the inside out as best you can, particularly the top of the compartment.
Plz rate my solution.
Thanks.
Jan 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Real Basic Question
Unfortunately, that top light isn't very helpful as it's an indicator for several problems (IE: Front door open, out of paper, incorrect/improperly installed print cartridge, etc.), so really, the only things you can do since you've already eliminated the 'out of paper' scheme is make sure the front door's 'button pusher' is still attached and pressing the internal button in the printer, and re-seating the print cartridge. All the help I can offer, I'm afraid.
Manual: http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/bpl04109/bpl04109.pdf
-Backu
Jan 19, 2008 | HP LaserJet 5L Printer
Ricoh Aficio CL3000 Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
