Question about Coffee Makers & Espresso Machines
Water is only hot for the first part and then it runs cold what is wrong.
    Scholar:
  • 154 Answers
Sounds like it needs descaling Fay, as simple as that. Follow the instructions in the manual. If you don't want to use commercial descalers then you can use ordinary white vinegar instead, it works just as well but takes a little longer to complete the job.
Posted on Apr 21, 2015
Testimonial: "Sorry but I have run the descaler through twice. Maybe I will try a third time."
How do I get the hot water work for my Fisher & Paykel Eco Smart washer?
How hot is the water temp in the house that you are in? If the inlet hose to the washer is not hot, then it is not the washing machine.
Jul 31, 2014 | Fisher Paykel EcoSmart GWL15
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
I pull the start botton and it does not start or load water. and I don't know what is wrong with my machine.
ok lets see here,, first we need to make sure your timer is working, put it in a spin cycle and let it run and see if it shuts off ,, if it does your timer MIGHT NOT be bad try and see if it will fill with hot water, then warm, then cold,, if it fills with hot i is the cold side of your water valve, if it fills with cold its the hot water side of your valve,, if hot and cold doesnt work it could be your wter valve, or your pressure switch
Jan 19, 2011 | Kenmore Washing Machines
Cold water runs through the faucet shower but no water at all through hot water side
If no hot water at any faucet, and your sure water in water heater is hot, check by-pass at back of tank for wrong positioning.
Jun 25, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
GOT GERMAN INSTRUCTION BOOK AND OPERATING GUIDE NEED ENGLISH ONE. PLUS ONLY ONE WATER PIPE DO I NEED A CONNECTOR PIPE TO CONNECT HOT AND COLD WATER PIPES INTO ONE OR DOES THE MACHINE HEAT THE WATER UP ITS...
for the instruction manual... you can "googe" search online for it...type your brand name in the search window with "support" and you'll most likely find the factory website with manual downloads.
For the water issue: most washers are designed to connect to a hot and cold water supply. If yours is a one water pipe connection, and you're ok with cold water washes, I'd recommend supplying water to both the hot and cold connections of the washer, so you don't have any mishaps by hitting the wrong wash cycle and not getting any water. You could purchase a simple hose bib splitter fo accomplish this.
If however, you want hot water, sounds like a plumbing job to bring hot water to the washer's location.
It won't hurt the machine to run cold water to both sides...you just won't get the hot water cleaning benefit.
Jun 29, 2009 | Whirlpool Washing Machines
Never Runs Cold Water LG Model WM0532HW
When set to Cold it Fills Hot ?
What does it rinse with ?
Have you had the fill pipes off the back for some reason and put them back wrong or has a plumber been messing with the supplies
If the machine is told to fill cold it should, it should also use cold water to rinse with.
What hapens if you tell it to fill Hot only
Jun 13, 2009 | LG WM-1832C Front Load Washer
Cold/Hot water
if this is a machine with two fill hoses, then you have them the wrong way round. to check, put on rinse and cold water should come in. if not, swap the hoses round. don't rely on what you house plumbing says is hot or cold - this is often wrong
Aug 28, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Coffee Makers & Espresso Machines Logo
140 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
