I need my AC adapter replace - Computers & Internet
    Top Expert:
  • 10,875 Answers
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Laptop reboots when ac adapter reattached.
There are three parts in the computer that you need to check.
1. Ac Adapter - it could be defective.
2. Battery - it could be that the battery and ac adapter won't work together because the battery has gone bad. We cannot tell without checking that.
3. Motherboard - it could be that the motherboard's power port is defective.
Do the following so that you can isolate the problem.
1. Remove the battery and use the Ac Adapter only and turn on your computer. If it turns on without any problem, then replace your battery.
2. If the computer still reboots with the ac adapter plugged in (no battery), then replace the ac adapter. or try using a different ac adapter which is compatible with your computer and check if it produces the same problem. If the other adapter produces the same problem, then it's in your motherboard and you need to get it fixed by a technician.
David
Jun 09, 2013 | Computers & Internet
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
XPS M1210 Laptop not powering up
No Power Issues on Laptops
There are 3 things to consider in order for you to determine a No Power Issue
1. Battery
2. Mother Board
3. AC Adapter
1. Remove the battery from the laptop
2. Disconnect all non essential cables (external hard drive, usb memory key, printer...etc.)just connect the AC Adapter
3. Take out the Battery....Usually there is a battery indicator that you can push at the back of the battery
4. By Now the battery power indicator should be full since it was never taken out
5. If still theres no light on the battery.... replace battery
6. Turn the laptop on without the battery
7. If the computer still did not turned on check the AC Adapter if there is light coming out
8. If there's no light that comes out from the AC Adapter. Reseat the cable from the AC Adapter to the Cord
9. Check if there is no light that comes out from the AC Adapter. AC adapter needs to be replaced
10. Otherwise the Mother Board needs replacing
May 17, 2011 | Computers & Internet
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
AC Adapter
Ususally the model number s located in the battery compartment or on the bottom of the player.  Check ebay for an adapter.  Usually you can find an adapter that is universal for all durabrand dvd players.
Jan 06, 2009 | Durabrand PDV-709
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Computers & Internet Logo
David Payne
David Payne
